So I am well aware of the fact that the Inner Tie rods for the 240/260/280 are NLA from almost all sources, but I am wondering if somebody has found a solution for a worn out inner tie rod! Seems crazy that either everyone has perfect tie rods, or is living with crap ones.
I've had a couple of ideas, but none of them are easy/require lots of machining. Looking for a good solution!
Link to post
I'm sure someone will correct me if I'm wrong, but IIRC, you can just use two right-side inners, and just use a right-side outer on the left side.
Edit: and a word of caution - don't buy the inners if they're still listed on RockAuto. They're wrong. Ask me how I know :)
Edited by Dershum
Link to post
