280 clutch problem
I have a 78Z, got a new clutch from the dealer (not the key value but the actual oem parts) and when i got it all back together there was a grinding noise between clutch engage/disengagement so I pulled the trans back out and the rivets on the disc hub were running against the inside rivets on the pressure plate.. Anyone ever seen that?
Not really sure what you mean by rivets.  I don't see any projecting rivets on my spare clutch disc and can't imagine any projecting in from the pressure plate to where they might rub.  Pictures? (damaged parts are always fun to look at).
I have rubbed the springs in a clutch hub on the flywheel bolts when I put it in backward.  That was a small block chevy.
