Eclipse seats
BallZ
Not sure of the year of the seats, with that being said the measurements work width wise, but my hold up is the front bracket welded to the floor. Would I be ok cutting the welded front floor mounting piece out? or do I risk other problem's by doing this?
Thank for the insight tried searching for awhile but came up with way to many results...Ryan
I was looking at the 2010 Eclipse seats.  they look really similar to the stock S30 seats but are upgraded a bit. I almost bought some, but found a set of 350Z seats in mint so I'm going with those...  You should be fine cutting the bracket, but you may need to weld to repair and mount it in an S30.
