Hi guys,
I want to know if any has any MS2 MSQ or map they can share for my new setup.
Im running MS-II PCBv3 4 bar MAPDADDY
My set up is build L28et with P90 head and N42 manifold
L28ET bored out to 88mm
Ratio is at 9:1
Schneider cam 284-70F
Head is mildly ported
-T3/T4 hybrid turbo
-AEM 50-1200 electric fuel pump
-upgraded fuel rail
-240sx TB
-Arizona Z TB spacer
-CX racing FMIC
-3 inch exhaust
-FORD EDIS 36-1 trigger wheel with VR sensor.  Still on the Ford Module with Coil on plugs.
-injectors are 480cc at 43.5psi (3bar)
You guys were such a big help last time so I thought I’d ask again. I’m getting the car tune but my tuner has me waiting. So I thought I’d ask to see if someone has a tune I can use for now.
Also any suggestion on a spark plug I’m using the NGK coppers with a smaller gap.
Thanks
Manny
