Rb26 bell housing brace
ktown z
I am in need of the brace that bolts onto the sides of the rear of the block that is used to bolt the lower part of the bell housing to the block. Does anyone know where I could pick one up or the part number so i could order a new one?
Thanks,
James
The AWD blocks do not have the provision for those prices as they relay on the cast oil pan to complete the "bolt up" to the oil pan.
Where as the RWD RB blocks have the bolt holes and clearance for those brackets with use with a RWD pan.
We have those braces but I doubt you'll find much use with them on your current setup without modifying them some how.
