welding rig power
Depends on the rig. I have a rig that requires 220v and one that uses 110v. The 220v setup requires a 50 amp circuit where as the 110 only requires 30. A lot of the larger power tools will require a 220 drop. A 50 amp circuit should hold anything that wI'll fit into a home work shop. Best bet, call a local electrician for the real nitty gritty.
