sr20?
Guest Anonymous
Guest Anonymous
Has anyone seen a S30 with a sr20d engine stuck in it? Prefferably a turbocharged sr20d?
Just popped in my head.... 250ish horsepower without trying, and an extremely lightweight engine(aluminum 4 banged compared to an iron block 6 or 8 cyclinder). I bet you could save at least 200 pounds or more with such an engine?
Morgan morgan@z31.com
http://carfiche.com
http://z31.com
Morgan, that would be an awesome swap in an early light body. My friend here has an original '85 RHD Silvia with the 1.8L engine and it is pulling close to 400hp. The Silvia ran 12.0 @ 119+ on street tires with lots of wheelspin as you can surmise from the timeslip. That engine is being tweaked and put in a stripped down early 200SX. In case you are wondering, the Silvia is getting an RB25.
250hp is easy. Save at least 100lbs, entire engine behind the front wheels and combined with a 4.11 diff from a 200SX turbo.......
Scottie
71 240GN-Z
http://www.mindspring.com/~vscott911/gnz.html
Scottie is your friend MAZ , from okinawa? if so tell him clint said Hi and i finally decided on rb-26 for my 260 should be done in a month. If he dosnt remember me tell him im the one that couldnt keep a damn rotary together ;>
later clint
