Will an RB26 Head mated to an RB30 block fit an RB25 Tranny?
HybridHydra
I am gathering knowledge for when I finally want to do a RB swap to my 280z.
If I were to use an RB26 engine I would have to use an RB25 transmission, then is that it ? Will the shifter be in the same spot as a normal L28 with 4 speed?
But I read somewhere that the RB30 Block is significantly stronger than the RB26 block, so if I mated an RB26 head to an RB30 block, would the RB25 tranny be ok?
Or will an RB30 Block and tranny be ok for the 280z?
All RB blocks fit all RB trannies. they use the same bolt pattern for the bellhousing, and also interchange with the RD series (Diesel) engines.
The only thing you need to watch for it shifter position, not whether they fit the block.
