tarmac attack 0 Posted June 25, 2015 Share Posted June 25, 2015 (edited) Hey man, I stumbled across this thread looking for a wiring diagram for the same exact model haha. I just put myself in the same hole as you, only I have way more work ahead of me bringing mine back. I work for a restoration shop in New Jersey, hopefully this will be helpful to you. Priming your parts after bodywork and letting them sit for a while isn't a bad thing. Once you do your bodywork, treat any bare metal surfaces with some sort of metal pretreatment wipe. It will cause a chemical reaction on the surface to really help corrosion resistance. Then you can shoot some high build primer on, couple coats, then your good to go. Letting the parts sit in primer for a bit will let the primer really sink in to the bodywork. As long as they are kept somewhere dry, you'll be fine. Then you won't have to worry about any possible soaking show through the clear coat later on. Hope that helps. Good luck. Justin P.s. I suppose this is can also serve as my introduction post hahaha. Edited June 25, 2015 by tarmac attack Quote Link to post Share on other sites
Eric Z 0 Posted June 26, 2015 Author Share Posted June 26, 2015 (edited) With midterms about finished, I'm hoping to spend more time with the Z. Last night I whipped up a couple brackets to be bolted onto the strut towers to support the car while we flip it upside-down. I might end up using them to mount the rotisserie instead of the bumper brackets (they're just a little bit rotten) Priming your parts after bodywork and letting them sit for a while isn't a bad thing. Once you do your bodywork, treat any bare metal surfaces with some sort of metal pretreatment wipe. It will cause a chemical reaction on the surface to really help corrosion resistance. Then you can shoot some high build primer on, couple coats, then your good to go. Letting the parts sit in primer for a bit will let the primer really sink in to the bodywork. As long as they are kept somewhere dry, you'll be fine. Then you won't have to worry about any possible soaking show through the clear coat later on. Thanks Justin, it's definitely good to have a professional opinion on this. When I get around to sandblasting it, I'll do a coat of primer to prevent the rest of the car from disappearing while I'm trying to fix what's already gone. Would you recommend an epoxy primer for this kind of application? Eric Edited June 26, 2015 by Eric Z Quote Link to post Share on other sites
tarmac attack 0 Posted June 27, 2015 Share Posted June 27, 2015 Thanks Justin, it's definitely good to have a professional opinion on this. When I get around to sandblasting it, I'll do a coat of primer to prevent the rest of the car from disappearing while I'm trying to fix what's already gone. Would you recommend an epoxy primer for this kind of application? Eric Yup. Shoot it with epoxy and that'll keep everything sealed up as you make your body repairs. Quote Link to post Share on other sites
Eric Z 0 Posted July 14, 2015 Author Share Posted July 14, 2015 Thanks tamarac attack, I'll definitely be doing that. The 260 is up on the rotisserie finally. We ended up making one with some jacks I found lying around on either end for vertical adjustment. The car is supported by the strut towers instead of bumper brackets like usual, should give more stability while I'm cutting out the frame. It's got wheels on one end, and a hitch for the forklift on the other - works like a charm for moving the car between shops for working and storage. I'll be sandblasting her this coming weekend hopefully, and finally see exactly what kind of rust issues I've got to deal with - pretty excited. Eric Quote Link to post Share on other sites
rturbo 930 34 Posted July 14, 2015 Share Posted July 14, 2015 Hey, can you tell me more about that crank on your rotisserie? I've been looking for something like that. Quote Link to post Share on other sites
Jay Gadsby 2 Posted July 14, 2015 Share Posted July 14, 2015 It looks like the crank is actually for height adjustability. My boat trailer has the same setup. Just raises and lowers the leg. His pivot point appears to be mounted to the top of it with a through pin stopper. I like the height setup for sure. Quote Link to post Share on other sites
rturbo 930 34 Posted July 14, 2015 Share Posted July 14, 2015 Ah, figured it had a gear assembly or something. Oh well. Quote Link to post Share on other sites
Eric Z 0 Posted July 14, 2015 Author Share Posted July 14, 2015 (edited) Hey, can you tell me more about that crank on your rotisserie? I've been looking for something like that. The crank on either side is just to lift the jack up and down, they've got about a foot of travel. It should give enough flexibility to put the car at a comfortable working height. To spin it, I have a 1/2" bolt set screw on each side that just needs to be loosened, and then cranked tight to prevent the car from moving. The car rotates easily by hand as the spin axis is [as close as I could get] to the center of gravity of the car. Edited July 14, 2015 by Eric Z Quote Link to post Share on other sites
Eric Z 0 Posted July 14, 2015 Author Share Posted July 14, 2015 Ah, figured it had a gear assembly or something. Oh well. Nothing quite that cool I'm afraid. Eric Quote Link to post Share on other sites
Jay Gadsby 2 Posted July 14, 2015 Share Posted July 14, 2015 A bicycle gear with a mating worm gear should work. Got a picture in my head, may need to draw it up. Quote Link to post Share on other sites
Eric Z 0 Posted August 8, 2015 Author Share Posted August 8, 2015 New update here: It's been a few weeks, things have been busy, but some progress has been made. This past weekend we sand/media blasted the under-body and engine bay. Discovered a few rusty areas that more closely resemble a certain holey cheese than a car, but nothing that's not fixable with a bit of patience. We are using an industrial grade sandblaster, and are a bit afraid it will damage the body panels if we hit them too hard. The plan is to chemically strip the rest of the paint, then hit the rusty areas with a finer sandblaster - better safe than sorry. We did try to strip the exterior paint with crushed walnut media, but it wasn't hard enough to eat through the primer, just the paint... so we scratched that idea. Picked up some epoxy primer from a bodyshop buddy of mine, I was assured this is the best stuff. The writing on the side seems to verify that haha. On a sidenote, I've got a few plans for the steering wheel. The stock one wasn't in the best condition, and I've always loved the look of wood steering wheels, so I think I'll attempt at a steering wheel build as well - I want it to be some blend of classic with a sporty vibe, I haven't seen anything out there quite how I would like it. Below is a first iteration CAD model, a 3 piece sandwich reusing the stock spokes and metal ring. Let me know what you think! I'll throw a few pics up of the sandbalsted car later so you guys can see what kind of rust issues I get to deal with, I could use a little sympathy haha. Eric Quote Link to post Share on other sites
