Looking for blinker and headlight switch
stravi757
yes! I just replaced the old, cut up, mangled, spliced, rat chewed, burnt, dash harness with the the correct one(70-9/71). Then I later find out that it has later style (10/71 plus) switches in it as well.
But to answer youre question more detailed... The cars manufactured from 70-9/71 used a different dash harness as well as a blinker and headlight switch to match with it.
I believe the one on the right is from an early '71. You can see that the stock is more vertical than the other. If this is the one you are in need of PM me.
Daniel
Hi Dan, Thankyou for the photo, But its tough to tell from that angle. A picture of the plugs would tell me if its the correct one. If you have a moment some time later to send a picture of the plugs that would help.
