Roll cage kits?
I seen where jegs.com sells a tube chassis kit for a 1978 2+2 (http://www.jegs.com/i/Jegster/550/942605K1/10002/-1) and one for a 1973 Z (http://www.jegs.com/i/Jegster/550/942705K1/10002/-1) either of these kits work on my 1975 2+2?
Are you planning on building a drag racer? The chassis kit is set up for a 4 link.
chris
Edited by NCchris
Using such a kit would imply excising the stock frame-rails in the engine compartment, and what passes for "frame rails" spot-welded to the floorpan.  Assuredly this can all be done, and depending on one's objective, might be the best approach.  But do please note that it is highly unlikely to save time/labor/money by attempting to fit such a "kit" to the S30 tub.  One might as well jig-build an assembly and weld it into the tub.
