530ZX - In progress
Congrats on the kiddo! Always a tiring, frustrating, wonderful time. The car isn't going anywhere, enjoy the bundle of joy.
Thanks man!
Swapped out the dipstick as the stock fbody one wasn't working with the manifolds, plus its pretty stealth
Wrinkled up the thermostat housing and blacked the steam vent line
Bolted the trans up to set the final engine mount location and mockup the trans crossmember
Core support had to go.  Up and over is for the birds
Gave the trans tunnel the ol one-two shiatsu
Tick brass shift cup isn't quite fitting, probably will need shaved a bit or pressed in
ASCO rear sub frame swap kit
Power steering AN fittings
Also started my welding cart to get my welding skills good enough to install the rear sub frame kit :cheers:
Big thanks to a fellow ls1tech member for the new clutch bleeder fitting
Hey man can i message you or get your number on how to specifically bypass the stock theft system? My plan is to keep all stock gauges if possible, anything special you had to do on getting them to work? Like speedo and tach, 5.3/4l80e is what im doing.. Thank you in advance!
I'll have to go look at it again, but i believe i hijacked a 12v source and tied it into the appropriate wire off the key harness.  I then had to run a wire from the ignition directly to the starter.  As for the gauges, I believe i'm going to run all new speedhuts.  Was looking at the racepak, but its a bit more than i'm willing to spend at the moment.  But anyway, yeah send me a PM
Edited by jshapaka
  • 4 weeks later...
In the process of moving so I had to wrap up everything enough to get it ready to move.
So anyway I finished up the cart for the most part.  Still going to add some additional pieces for the grinders, clamps and supplies
I need a plasma, I wore this thing out cutting the diamond plate
Ensured the engine was level side to side
Prothane trans mount
Being new to metal fabrication, I figured I'd mock up the cross member in poplar to get the measurements and angles close
Cross member is made out of 1/4" flat with 3/16" gussets
30 yr old bolts that didn't allow for a box end or a ratchet equaled a sweet brown situation
Shes loaded down and ready for the move so it may be a few weeks before the next update
  • 6 months later...
I’ve been extremely busy with many things; however, there is still progress being made, albeit slowly.  Backfilling since my last update:
May 2016
Picked up a flare kit and deburr tool for the BMC line
Picked up a plasma cutter
New house with a two-car garage, DOUBLE THE SPACE!
June 2016
Back out.  Should be for the last time hopefully
Here's where I let the scope of the project run a bit rampant.  Decided I wanted to continue the "Learn All Things" ideology and spray the bay and cab.
Picked up another jack to get under the vette without having to use ramps.  It’s from HF, but it’s actually pretty nice
Rebranded
Bought a press too since I’ve been wanting one for a while and I’ll need it for dimple dies
Then I had the idea that if I was going to through the trouble of spraying the interior, I may as well cage it now.  So of course, instead of buying a cage, I had to stay true to the theme and build the cage myself.   Over the course of the next several months, I researched a great deal, ordered parts, and built what I needed.
Settled on a JD2 Model 32
July 2016
JD2 Notchmaster
Bendtech Pro
JD2 1.75” Die came in
Learning the software
August 2016
Put together a close model with some actual measurements so I could get the tube ordered
Picked up tube
Getting the base plate locations cleaned up
September 2016
Base plates for the main hoop
Picked up a needler and a mini sander to get into the tight areas
Started bending the main hoop
Hoop X-braces
Rear down tubes
Front down tubes
October 2016
Driver’s side front down tube
Down tube support
Halo supports
Deadblow got a little away from me
Windshield removal.  Tried a couple of tools but they didn’t work in the least, so I resorted to the brute force approach
Finally decided to do what I should’ve done a long time ago and remove the body harness and steering column
Cutting the floor to drop the cage
