Hey Guys,
Newbie question, I have 240Z with 2.6 liter motor with E88 Head. I have a spare F54 series short block with flattop piston, crankshaft, etc. Wanted to know if i can use the short block with my heads and stock camshaft without replacing the the spring, rocker arms and use the old one without running into nay problems?
This is one of those "if you have to ask" questions.  If you have to ask, then you'll probably run into problems.
In principle, the E88 head, complete with cam, rockers, etc., should bolt right on easily, giving you a typical L28 engine but with smaller valves.  Basically a flow-choked L28.  Apparently there are several E88 varieties though.  Better learn more about what you really have.
http://www.ozdat.com/ozdatonline/enginedesign/
http://www.zhome.com/ZCMnL/tech/head.htm
