Running Rich or electrical problem?
Seems like a lot of mixture questions today so I might as well throw mine out there too.
77' 280z. Sometimes she turns right over some times I have to pump the gas few times and hold a little open throttle till I hear the belt slip the revs level out. I figured it was just the alternator and belt going but the voltage output is solid.
Then I started to notice the sulfuric egg smell when I opened her up and started to think it was deposits in the cat so maybe I'm running rich or maybe I'm not getting a solid spark?
Cat, plugs(but not distributor), and fuel filter are less then a year. Compression checks good and plugs don't look fouled last time I checked.
I do have problem with my deceleration valve not letting the revs come down until I'm at a full stop.
Bunch of symptoms are starting to look like they are all pointing to the same root problem. I'm just sure what it is. Any advice?
Sounds like you're saying that your engine doesn't smooth out after starting as quickly as it used to.  Sometime there's a smell.  And your idle speed hangs high.  I'm not really seeing a connection, or much of a problem.  When did it last have a tune-up?  The sulfur smell is a product of the gasoline quality, I believe.  And the hanging idle could be a gummed up throttle blade.  Gunk from the PCV system can coat the intake all the way back to the throttle body.
A good tune-up and cleaning of the throttle body might get you back to normal.
6 months maybe. I'll have to check my Papwork if they checked the throttle body.
I know they checked compression, fuel air mix and And replaced the hoseing bits in the fuel rail and the fuel return check valve.
