Sign in to follow this
Ben280
1972 Datsun 240Z Project $4500
1972 Datsun 240Z Project SOLD!!!!!!
SOLD!!!
Awesome clean 240, would be a great cruiser with weekend racer potential, or a great base for a vintage race car. This was a 100% running car until I took the motor out of it. A complete L28/5sp is included, but the motor needs a rebuild. A good rebuilt running motor would make this into a fabulous car.
CLEAN OREGON TITLE IN HAND!
240z shell with good paint, and minimum rust. Clean dog-legs, lower fenders, lower valence, no rust in the battery tray, hatch tray or in the hatch itself, very clean gas cap area, no dents or dings. Some paint chips, but overall the paint is 8/10.
Engine: N42 L80 with N47 head. MSA 3-2 header. Rebello prepared twin SU carbs flow ported, tuned needles and jets set for autocross, Fuel tank acid cleaned and POR 15 sealed, Mallory HyFire 6 - digital ignition control, relocated light weight battery, dual electric cooling fans, electric fuel pump.
Driveline: 5sp Transmission, Subaru R160 LSD diff, out of an SVX, CV axle conversion. Modern Motorsport rear disk brake conversion using 240sx rear calipers. Stainless brake lines front and rear, Hawk HP plus brake pads.
Suspension: Adjustable coil overs, springs with 320 lbs front and 400lbs back, corner balanced, lowered 1.7", Tokico five position adjustable shocks, adjustable camber plates, adjustable caster control arms, rear caster and camber adjustable concentric bolts, Two front sway bars racing 7/8" and softer 3/4", front and rear shock tower braces.
Body/Interior: 4 point welded roll bar installed, custom front to rear body stiffening frame rails, Recaro seats with 5 point racing harness. Clean mostly complete interior, capped dash, solid center console, good transmission tunnel upholstery, great condition headliner and sun visors. Momo steering wheel, aftermarket tach with programmable shift light. Working locks, Techno Toy Tuning tow hooks front and rear
Front and rear 240z bumpers in good shape, ZG flares, Type 1 airdam, headlight covers.
Lots more high resolution images in the gallery: https://imgur.com/a/srrYY Car is located in Portland Oregon.
Edited by Ben280
Share this post
Link to post
This topic is now closed to further replies.
