exlifesaver Posted December 20, 2021 Author Share Posted December 20, 2021 S30forever Thank you for inquiring on the MFactory R200 Differential. The Differential is priced as low as possible. The cost is $875.00 shipped to the lower 48 states. Any questions that I can answer please continue this post. Thank you Chip Quote Link to comment Share on other sites More sharing options...
SH4DY Posted January 21, 2022 Share Posted January 21, 2022 I can vouch for Chip and the MFactory unit. My car makes ~450rwtq and this unit has had no issues handling it, even on drag radials. No one wheel peels here or dealing with clunking/ popping from a welded diff. Quote Link to comment Share on other sites More sharing options...
exlifesaver Posted January 22, 2022 Author Share Posted January 22, 2022 Thanks for the kind words SHADY. Always nice to here. Enjoy. Chip Quote Link to comment Share on other sites More sharing options...
exlifesaver Posted January 22, 2022 Author Share Posted January 22, 2022 Excuse me SH4DY Sorry for the mispell Quote Link to comment Share on other sites More sharing options...
Z-TARD Posted February 6, 2022 Share Posted February 6, 2022 PM sent Chip. I'd love to snag one if still available. Quote Link to comment Share on other sites More sharing options...
Z-TARD Posted February 13, 2022 Share Posted February 13, 2022 Huge thanks to Chip, he had my differential shipped out extremely fast, it showed up 2 days ago. Looks like a very high quality part and I'm looking forward to getting it installed once the weather warms up a bit. Quote Link to comment Share on other sites More sharing options...
Ratatatz Posted May 24, 2022 Share Posted May 24, 2022 Been happy abusing my unit😤 cammed/heads/intake ls/t56 with the r200 mfactory lsd. Way better than welded diff. No regrets or complaints yet since 9/2021 Quote Link to comment Share on other sites More sharing options...
exlifesaver Posted May 24, 2022 Author Share Posted May 24, 2022 Ratatatz Thanks for the kind words. Keep enjoying . You have been a great customer. Chip Quote Link to comment Share on other sites More sharing options...
TurboDan Posted May 27, 2022 Share Posted May 27, 2022 Hi Chip, just curious what the current cost and availability is? Also, is this a 1 / 1.5 / 2 way? I'm starting to research LSD's for my '75 280z and am trying to learn what's what. Thanks! Dan Quote Link to comment Share on other sites More sharing options...
exlifesaver Posted May 27, 2022 Author Share Posted May 27, 2022 TurboDan Thank you for inquiring about the MFactory R200 LSD. Price is $925.00 shipped to the lower 48 states. I have one available at this time. Toward the end of June others will be available. I'm not sure about the numbers you are using . This is a Helical LSD. It's locked on acceleration and deceleration. your '75 280Z I believe has the 3.545 gearing 29 spline stub axles. If you can define the numbers you listed I may be able to assist you better. The ways numbers may be associated with clutch type LSD's maybe. Thank you Contact me any time. Chip Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 28, 2022 Share Posted May 28, 2022 One way limits slip on accel (common for FWD). 1.5 way limits some on decel, more on accel. 2 way does both accel and decel equally. FWIW, a limited slip doesn't "lock" but a locker does. That means even if you lift one tire off the ground, the tire on the ground will still get power. A limited slip limits, unload a tire and it will spin. High end 1.5 ways are adjustable by changing the ramp angles on the cross pin shaft. If you do sim racing you can see adjustments for percentage lock under accel and decel, that's adjusting the slip for each. Here is a screen from Assetto Corsa. This fully adjustable limited slip is set up basically like a 2 way. Should probably back off that decel a bit, but it's fairly stable under braking. 2 ways are nice for drifters because they tend to make the car loose on corner entry. If I jacked up the power and coast settings the car would act more like a welded rear end. If I lowered them all the way it would be like having no LSD at all. Helicals can be set up to do any of the 3 options, 1, 1.5, or 2 way. Quote Link to comment Share on other sites More sharing options...
TurboDan Posted June 6, 2022 Share Posted June 6, 2022 Thank you both Chip and Jon for that info... I am still researching the different diff's available and the Mfactory seems to have very good reviews (at least from other car models, haven't seen many Datsuns with them except for a few on here). I did have another question regarding the 10mm vs 12mm bolts (I honestly do not know what i have yet, but I do think it's a 3.54 gear ratio). You had mentioned in an older post about shims, is that info needed or has this diff been modified to accommodate either bolt size? At least now I understand that this is a torsen style diff, so much less maintenance (less gear oil changes and no clutches to wear out). The one downfall I've read is some aggressive courses with curbs that get one tire in the air will force it to lose traction, but I don't think i'll be in that scenario often. I'm 95% street, and occasional autocross in a flat parking lot (for now). Thanks guys. Dan Quote Link to comment Share on other sites More sharing options...
exlifesaver Posted June 6, 2022 Author Share Posted June 6, 2022 Dan The LSD has 10 and 12 mm bolts holes. Yes your "75 280Z is a 3.545 The shims on either side of the open diff. are reusable on the MFactory. Just remember to put them back on the correct side. The shims could be different sizes by a small amount. Matter of fact when disassembling make sure whats on the right side of the diff goes back and same on the left side. Same with bearing caps and mark them with a marker as to the up position as they were removed. Thank you Chip Quote Link to comment Share on other sites More sharing options...
TurboDan Posted October 24, 2022 Share Posted October 24, 2022 Shoutout to Chip for awesome communication and customer service. I got my Mfactory LSD quickly, and my 280z is a different animal now. No more one legging coming out of sharp turns, and a much better launch (haven't really gone crazy dumping the clutch or anything, but a few chirps and she's gone). Thank you sir! Here's a recent video from the last autocross event. Quote Link to comment Share on other sites More sharing options...
Northern Z Posted December 9, 2022 Share Posted December 9, 2022 I'm interested if still available and do you ship to Canada Thanks Quote Link to comment Share on other sites More sharing options...
exlifesaver Posted December 9, 2022 Author Share Posted December 9, 2022 10 hours ago, Northern Z said: I'm interested if still available and do you ship to Canada Thanks LSD's still available, $949.99 (Northern Z) Shipping and any custom fees you will have to pay. To get an estimate on shipping I will need your name and full shipping address Thank you for inquiring Chip Quote Link to comment Share on other sites More sharing options...
S30forever Posted February 19, 2023 Share Posted February 19, 2023 Interested in purchasing Mfactory lsd for my r200 long nose differential, (depending on price). Sent you an email as well. Thanks Quote Link to comment Share on other sites More sharing options...
73Ed Posted October 15, 2023 Share Posted October 15, 2023 Thanks a lot Chip (exlifesaver) Got my diff delivered in less than 2 days and everything looks great so far.. Quote Link to comment Share on other sites More sharing options...
exlifesaver Posted October 15, 2023 Author Share Posted October 15, 2023 Nice Glad all is going well with your build. From your pic Ring gear looks really good. Chip Quote Link to comment Share on other sites More sharing options...
