GabeDiaZ27 0 Posted November 22, 2017 Share Posted November 22, 2017 (edited) OK, So heres what im dealing with right now. My rb20 is having some weird issues running, Idle is good at a 14.7 AFR but under load/driving is where I get problems. Upon initial acceleration or low rpm`s the engine has little power and runs like its missing a cylinder or two with afr`s dipping into the 10`s then as boost comes on it runs normal for a bit like it should with afr`s towards 12-13`s and as the rpm`s raise and I hit full boost it will sputter and pop as it leans all the way out untill my wideband cant go any higher (18+ afr`s). So far I have checked everything manually and also through nistune and I still cant figure it out. Here is my current setup: Stock RB20DET and stock turbo Z32 MAF Nistune chipped ECU RB26 444CC injectors (and resistor wired into the harness) Walbro 255 fuel pump Nismo FPR AEM Wideband I have checked the timing and its at 15 deg. Fuel pump has good power and ground. All injectors are opening/closing. All coilpacks work (I pulled them with the plugs and spun the CAS to double check). ECU dosent pull any codes. Fuel pressure isn`t dropping off. TPS voltage is good. Plugs look good and are gapped to the reccomended .8, The MAF readings look linear and accurate from what I can tell through nistune. If I go into nistune and bump up the fuel it just runs richer in the lower rpm`s and still leans out and pops. The only things left I can think of is a bad MAF, Low voltage to the pump under boost, A bad ignitor for the coilpacks, or possibly a bad CAS or something. Any help would be greatly appreciated because I dont know what else I should check at this point lol. Edited November 22, 2017 by GabeDiaZ27 Quote Link to post Share on other sites
jthom5147 1 Posted November 22, 2017 Share Posted November 22, 2017 Sounds like TPS. Quote Link to post Share on other sites
