Patton Machine EFI
Dadddio
  • 3 weeks later...
I'm doing Rick's kit now and it is great. I've got a lot of it done, but the car won't be running for a few months. I'm in the process of putting the car back together after a complete tear down to metal. the kit itself is done very good, I had affordable fuel injection do my dizzy so the computer can control the timing. I also mounted most of the sensors on the air cleaner backing plate so I had to lengthen some wires.
Larry.
Installing a larger fuel line was the hardest part for me to this point.
Swapped my 240 fuel tank for a '75 280.
Getting ready install the kit next.
Where did you mount the pressure regulator?
How did you route your fuel lines?
Thanks for the response Larry.
- Chris M.
I mounted the regulator on the fire wall near the heater hoses. I the fuel lines in the same place the factory did, I made new rubber insulators so the fuel lines would fit. I did my fuel lines out of -8 steel braided so I had to make an extra rubber block to hold the return line, I put it in between the factory ones and used a steel tie strap to hold it in place.
I've  got a '72 240z by the way.
Hadn't thought of putting it there.
I was going to put it on the PS fender.
I'm planning on making some brackets for the 2 fuel lines and mount them in the stock location over to the carbs.
May do braided, not sure yet.
Think you could post a couple pictures?
Thanks again.
  • 2 months later...
  • 2 months later...
I recently got four boxes in the mail from Rick...after 10 years he finally got back the last of my SU Body Samples to me!
Trust me when I say, Rick Patton can supply an adapter for ANY Datsun SU from 65 through 78!
I know, I sent him a pair of each to make samples from...this will also apply to Isuzu, Toyota, and many other Japanese cars that used Hitachi-Produced SU's during that timeframe.
Yes, you could put these on a roadster, he has the patterns to do it!
One incident of my hoarde being used for the betterment of the rest of Datsun-dom!
Sorry for the delay.
Tony, it was your endorsement that convinced me to go this route....Thanks.
It was not as easy as it seems, but if I could do it most people could.
Turned out to be a very clean install in my opinion. Starts right up everytime. Idles high and drops just like it's supposed to. Only issue is after running a data log it seems I'm running lean.
Checked everything, can't seem to locate any issues. Any ideas?
  • 4 months later...
I just sent a check to Rick this week to get started on this myself.
Did you guys start with 3-screw SUs? I have 4-screw SUs mounted in my car, but I have a set of 3-screws ready to modify.
I already have a FPR  and fuel pressure gauge mounted in the engine bay when I swapped out the electric fuel pump for a Holley fuel pump. The headers have the bung for the O2 sensor, and I also ran braided hose to route the fuel lines away from the heat from the headers.
I anticipate having to get a richer fuel map once I have it installed and tested.
