ignition switch?
brickit
It’s possible. I’ve not seen them fail where the dash lights stay on with the key off.
So how are you getting the dash lights back off once they are on?  Does the pump come on when you initially turn the key to on or only when you turn off? New switches are pretty cheap. I’d replace it and see what happens.
Ok  put new ignition switch in and same thing. disconnect ignition switch no change. I unplug and plug in again alt. and get a slight sound change but all stays on.  Brake lights work but not bright, headlights not at all. Sorry not good with multi  meter.
  • 3 weeks later...
