DaEvil 10 Posted July 19, 2018 Share Posted July 19, 2018 Hi, I'm out of ideas !! I need some advice on what is making my gauges go nuts. I finished my car for the second time . First time I got 10 good years out of it. Make a long story short I have been driving the car for the last three months everything is good . Than about a week ago when I let my clutch out my gauges go nuts. Its only in forward gears not reverse. I have gone through all the connection and grounds,14 volts at the battery ,unplug the alternator and they still go crazy, I disconnected the cable X box still no change. Also the stereo turns on and off. If anyone has any ideas I would love to hear them .Thanks in advance. Quote Link to post Share on other sites
trackzpeed 9 Posted July 19, 2018 Share Posted July 19, 2018 Voltage regulator? Not sure if that would cause that but it’s my first thought. Quote Link to post Share on other sites
Richard Oben 3 Posted July 19, 2018 Share Posted July 19, 2018 Something is loose all those items get ignition/accessory power. Check all the main connections that feed the fuse box. Just guessing. Richard. Quote Link to post Share on other sites
DaEvil 10 Posted July 19, 2018 Author Share Posted July 19, 2018 (edited) I thought it might be the regulator but I disconnected the alternator and had no change. I will double check the fuse box connections. I install a new fuse box with the bladed fuse . Thanks guys Edited July 19, 2018 by DaEvil mis spell Quote Link to post Share on other sites
JoeK 2 Posted July 19, 2018 Share Posted July 19, 2018 Check your wiring pathways. Look for abraided wires, or wires that are near any moving parts. You could have worn some insulation off a wire and are getting intermittent grounds. Quote Link to post Share on other sites
DaEvil 10 Posted July 20, 2018 Author Share Posted July 20, 2018 I have checked everywhere but behind the dash (what I can't see). I guess I'll be pulling the dash out soon Quote Link to post Share on other sites
DaEvil 10 Posted July 21, 2018 Author Share Posted July 21, 2018 Fixed !! I ran a new #2 ground wire from the left front Head to the left chassis . Thanks for all the help Quote Link to post Share on other sites
JoeK 2 Posted July 21, 2018 Share Posted July 21, 2018 Glad you got it working. Loose or funky grounds are the most common electrical problem. Quote Link to post Share on other sites
