captainkim
Valve cover for Chevy Short block
I have a 71 240z that has a SBC in it.   my valve covers were leaking and cracked so i wanted to replace them but ...the original covers had an oil filler cap hole and two other holes for the breather.   Ive looked around for a replacement but found some that they only have 2 holes for the breather and none for the oil cap.
Can I use this valve cover and just use one breather and use the other hole to put a cap plug.  Do i have to get a cover with 3 holes or can i use the ones with just two with out oil cap hole
thanks
Share this post
Link to post
All you need is one oil fill hole and one breather hole. Many choices with one screw in cap and one breather.
You need to keep at least one breather.
Talk to a tech at Summit Racing for advice on the cover and gasket choices.
For example: https://www.summitracing.com/parts/edl-4144/overview/make/chevrolet
Take your pick:  https://www.summitracing.com/search/make/chevrolet/engine-size/5-7l-350/engine-family/chevy-small-block-gen-i?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=edelbrock valve covers
Edited by Miles
Share this post
Link to post
The ones Ive been looking at have two holes but they arent designed for screw in oil cap but ...I "think" an oil plug.  Would that work?
https://www.amazon.com/SPECIALTIES-POLISHED-ALUMINUM-CHEVROLET-PERMALIGN/dp/B016CKPOKW
Also...I have a shorty....but is there any harm in getting a tall valve cover even though i dont need it?
thanks!!
Share this post
Link to post
Wow, $300 for valve covers??  Pretty pricey.
Regarding tall vs short covers...I used to have tall covers and found they were always in the way of my intake plumbing, etc.  Switched to shorts.  On the other hand, some short covers may have interference issues with some types of rocker arms.
Have been using the Fel-Pro gaskets with steel core and ribbed rubber for years without any leaks.
Hope this helps.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
