1977 280z 1jzgte
Link g4+ monsoon stand alone ECU,Panic Wire harness,10lb flywheel, 264 cam shafts, Head ported (intake side only), Adjustable cam gears,
Eclutchmasters 6 puck unsprung clutch and pressure plate (stage 4)Drift Motion turbo kit Billet 6262 turbo (Garrett internals), manifold, wastegate tial replica, and 3" downpipe, Hks bov replica, Aeromotive fuel pressure regulator, 440cc injectors,Bosch 044 fuel pump, Arp head studs, Aem wideband
Short throw shifter, a/c and p/s delete (shortened serpentine belt and new ribbed pulley on tensioner),vvti coils wasted spark setup, CX racing intercooler ,
Edited by 1jzs30
Typo
15 minutes ago, 1jzs30 said:
New to this site and this is my first ever build took a couple years to get this far I am open to suggestions or ideas or something that could be changed for the better please let me know
Edited by 1jzs30
On 2/9/2019 at 10:30 PM, 1jzs30 said:
Thank you, my original hoodlach was a little messed up too so I cut it off too , I flattened it back out in a vice and cut the top off and built a box under it with flat bar for stability, painted it  and re attached it with bolts to it's original spot weld holes I drilled out in order to remove it
Ok, so you just modified the original, that's cool. Have you noticed any flex in the latch while driving? Is it only held on by the two upper bolts?
Mine is a bit too mangled for that (and I wasn't particularly gentle in removing it once I decided it had to go), so I would have to make the whole thing from scratch.
The box design looks pretty good, is it open from the bottom?
The current plan is to clone this https://www.thezstore.com/page/TZS/PROD/classic13/10-1873 (because I think that's a little steep for two chunks of steel)
Nice I like that one in the link, yeah I only have the two bolts up top, I don't notice any hood bouncing while driving, I do have concerns about it flexing up like if I pop the hood and someone tries to open the hood without undoing the hook but as long as that doesn't happen it's pretty solid for normal operation. I have been thinking of just adding a third bolt underneath in the middle in the flat bar too!
