jkelly
240z and 280z parts
I'm nearing the end of my build and have several parts I don't need. Prices include shipping unless otherwise noted. I'm located in Tehachapi CA. Local pick up is fine, too.
  • N47 intake manifold with EGR block off plates (from a '78 280z) - $100 + shipping
  • Urethane Spindle Pin Bushing Kit (rear LCA outer bushings only) -- $20
  • Energy Suspension polyurethane compression rod bushings -- $15
  • Red Interior Plastic Rivets, 70 - 73 240z - $5 per pack of 10 (4 packs available)
  • '76 - '78 280z ECU Kick Panel Cover - $30
  • '78 280z Restored License Plate Light - $50
  • '78 280z Relay Bracket $25
  • 280z Horn Relay (tested) - $25
  • 280z Fuel Pump Relay 25230-H7200 (tested) - $25
  • 280z A/C Relay 25230-H7200 (tested) - $25
  • 280z Inhibitor Relay 25230-H7200 (tested) - $25
  • 280z EFI Main Relay 25230-89970 (tested) $15
  • 280z Fuel Pump Control Relay 25230-89966 $15
  • 280z OEM Right Side Pillar Badge (New) - $40
  • 240z Tailight Chrome Trim - $20
  • Side Marker Lenses - $5 each + shipping
  • Rear Side Marker Light Housings - $5 each + shipping (inside has been painted white)
  • Front Side Marker Light Housing - $5 + shipping (inside has been painted white)
  • New Side Marker Rubber Seals - $20 for all
  • Side Marker Chrome Trim Pieces - $5 each + shipping
  • Front Park/Turn Signal Rubber Seals - $15
  • 240z Painted Front Sway Bar - $20 + shipping
  • 3D Printed Flexible Inner Mud Flaps - $7.50 each
  • 3D Printed Flexible 240z Steering Column Firewall Gasket - $10 each
  • 3D Printed Firewall Wiper Grommet - $5.00 each
  • Custom 3D printed grommets, seals, gaskets, inspection light lenses, chair slider knobs, seat mechanism covers, etc. Contact me.
  • 280z 2+2 NEW  sewn-molded, black, cut-pile 5-piece carpet kit - $100 + shipping (like this http://www.thezstore.com/page/TZS/PROD/classic08g06b/40-2564  )
Edited by jkelly
Share this post
Link to post
On 3/28/2019 at 7:36 AM, Grog said:
I'll take the spindle pin bushings and side marker light rubber.
PM sent. Let me know because I'm making a run to USPS, UPS, and FedEx tomorrow.
23 hours ago, theczechone said:
Pictures of the 240z chrome tail light trim?
A sale is pending, but here are some pics. The plastic studs on the back that fasten it to the tailight are broken off.
Share this post
Link to post
1 hour ago, Larry Mahanor said:
Looking for a 3 wire 240Z tachometer. Most of them are 4 wire type with a square white 4 prong connector. The 3 wire type has 3 threaded studs on the back. Larry
Larry, I'll get my old tach down tonight and take a look at it and get back to you. James
Edited by jkelly
Share this post
Link to post
Interested in The top 3. I'm unsure if I need the steering column firewall currently as my interior is gutted? I could also use quite a few interior items like the seat mechanism covers. Just any interior plastics besides the dash and glovebox really. Thanks
Edited by j1valverde
Share this post
Link to post
Hey,
I'll print those up for you this week if you're sure you need them. I opted to replace my steering column firewall gasket because the original was falling apart and I had the steering column off for rebuilding. I can also print custom firewall wiring grommet sizes. For example, the one I printed for the wipers has a center hole size of about 3/8 to 1/2 inch which fits my wires nicely.
I have a model for the seat covers. I will try to print some test ones this week and see how they turn out.
Let me know if you want to go ahead with the first three items and I will get those made for you.
Thanks,
James
Share this post
Link to post
