Turn Signal Leftovers (I am an idiot)
So I decided to completely tear down my 1978 280z turn signal switch. I cleaned and lubed every moving part and it is 1000x times better now. However I am left with one extra ball bearing. There are a total of 3 bearings. The two larger ones go on each end of the rocker part. The last one is significantly smaller and I have no idea where it is supposed to sit. I honestly don't even remember taking that bearing out.
Does anyone know where it belongs?
5 hours ago, Miles said:
Look at the rocker inside the TS switch in the video.  See the center stalk that pushes the rockers? There should be a small ball bearing with a spring in the center stalk.
This is actually where the the 240z and 280z switches deviate the most. I've included a photo. I'm pretty confident the ball bearing does not go there. Has anyone seen a guide for the 280z switch?
Edited by munkey_mike
