stripped bolt hole dilemma
scartail
need help, and im not sure on the uniqueness of my dilemma, and im not sure of the proper category.
i found a broken exhuast stud in my head (engine from the yard). in my absence of forethought, i drilled a hole and attempted to extract using an extractor. you know what, the extractor broke. so, i had a broken harden steel extractor in a broken steel stud in an aluminum head. i eventually grinded a hole with  dremel. it's about a1/4" diameter hole.
now im certained with retapping the hole. what are my options? grind (because some hardened steel might b left) the hole out to tap for helicoil?
in retrospect, i should have welded something on and tried that. stupid of me.
any advice? thanks.
