What part is this?
I've looked through the FSM, my Haynes manual and searched forums on multiple sites.  I can't identify this part on top of the thermostat housing and where the hoses are supposed to be attached.
Any help is appreciated. Thanks!
I think this is a vacuum solenoid, used to interrupt the vacuum to the vacuum advance on the distributor.  The vacuum line on the right of your picture goes to the vacuum canister, via a T fitting that would be in the lower left of your picture.  The unconnected fitting goes to your vacuum advance on the distributor.  I can't find any direct discussion of this in the FSM, but I've looked at mine, and at related items in the FSM, where it is described (I think) as a 'vacuum switch solenoid', or 'vacuum cuiting solenoid', and is used in M/T non-CA models.
