Fidanza flywheel installation issues with Crankshaft
Stunt
I was having issues with installation of Fidanza flywheel onto my L28 crankshaft.  Bolt holes will line up but not able to install flywheel onto crankshaft as the diameter on the flywheel is not as big as Crankshaft.  I purchased the Fidanza flywheel from Jegs.com.  Will provide pics soon
Did your engine have an automatic transmission attached to it before? If so, be sure you've removed the flex plate spacer/adapter from the back of the crankshaft. It's sometimes pretty hard to tell its there, and a very common mistake.
