1980280ZXVQ35 0 Posted October 28, 2020 Share Posted October 28, 2020 I have a VQ35DE swap (engine/transmission) in a 280ZX and I'm trying to measure the driveshaft length I need. Typically it would be measured with the slip yoke pulled out 3/4" from the output shaft, for suspension travel, but since this is IRS the suspension travel does move the position of the rear end. So would I measure with the slip yoke inset all the way until it stops? Can someone confirm if on the 350Z, how far the driveshaft slip yoke goes into the transmission output shaft? Quote Link to post Share on other sites
G-Tech 4 Posted October 28, 2020 Share Posted October 28, 2020 i dont have the same swap as you but when i did a swap in my zx i explained to the driveshaft shop that the rear-end doesn't move and they took my fixed measurements and made it so the slip yoke goes half way in. this way when you install it, you can slid it all the way in 1st, then pull it out to mate with the rear-end. if you make the driveshaft length with the yoke fully seated, you would probably fight with it when you lift the back up to meet with the rear-end . Quote Link to post Share on other sites
1980280ZXVQ35 0 Posted October 28, 2020 Author Share Posted October 28, 2020 2 hours ago, G-Tech said: i dont have the same swap as you but when i did a swap in my zx i explained to the driveshaft shop that the rear-end doesn't move and they took my fixed measurements and made it so the slip yoke goes half way in. this way when you install it, you can slid it all the way in 1st, then pull it out to mate with the rear-end. if you make the driveshaft length with the yoke fully seated, you would probably fight with it when you lift the back up to meet with the rear-end . Yeah that makes sense, I just wonder how far the slip yoke needs to be inserted onto the output shaft. I actually have a driveshaft that I test fit and the slip yoke is about 1" from bottoming out, I just wonder if this is too far out. Thank you, Quote Link to post Share on other sites
260DET 32 Posted December 4, 2020 Share Posted December 4, 2020 If you give the driveshaft shop the flange face to flange face measurements that should be good enough for them, tell them the diff is locked to the body of course. Don't overthink it. Quote Link to post Share on other sites
