Rear hatch slam lid rust question
brianZortiz
Brian,
I just went through this nightmare. You will need to cut it all out. The rear hatch slam lid is actually four pieces of metal spot welded together. Two vertical pieces that flare out in opposite directions, one lower “backing” which is what bends and creates your hatch mounding life. The LAST piece is what is visible and available for $130 Online. I attached some photos of my cut and rebuild. It took 2-3 weekends. I don’t have a metal brake, so I had to weld the 90’s.
  • Like 1
I’m doing my slam plate and I’ve been considering using panel bond adhesive for my mine. I have pitting similar to yours in a few areas and already cut out and patched the few area that had holes all they way through. I was thinking of using panel bond extensively over the potted areas and doing a few plug welds around the edges and on the two brackets that go above the license plate. I think the PB should help the rust from returning and some well placed seam sealer should keep water from getting back under there.
There's a company in the UK that's producing hard-to-find replacement body panels, and the rear slam panel is one of them.  Looks like they do pretty nice work.  There may be other vendors doing similar work; but I just happened to notice their ad the other day on FB:  username was "Kim Mays" on the "Datsun Parts and Needs" FB page.
Here's a link; but may not work for you if you're not a member of the group:  https://www.facebook.com/photo?fbid=1661652560538618&set=pcb.1655145461187252
Por-15 sells a seam sealer on amazon. It’s made from a. Thicker formulation of thier standard product. It’s non-porous and will encapsulate the metal when used on a degreased prepared metal surface.
you can try to plug weld the holes but in my experience the steel necks-down where there is significant enough corrosion to cause a hole. Therefore, the second you zap it, the surrounding metal melts away, making a mess and a much larger hole. Still. If you are skilled you can very slowly add metal to the diameter of the hole, fill-in the hole, then grind flush from both sides.
honestly, in the end I was happy I cut and replaced the whole thing.
one thing I recall, is there was a TON of rust stuck between the spot welded panels. This is something you just dont see unless you start cutting into it. I bought the car with what seems to be 50 years of "temporary" fixes. I saw silicone, brazing, all sorts of stuff. None of it helped prevent the corrosion forming between the panels. When I separated them, id say 20-50% of the metal had corroded between, and so the surface metal was much thinner than you could see from the outside.
Thanks all for suggestion. I will go with cutting the potted rust and putting fresh metal. Plan on having this car for a long time.
I’m in Datsun parts and needs. Thanks for the link, but it seems they don’t advertise the bottom side of slam panel which is pictured. The top I got from MSA
