Electric power steering, use complete donor column?
3 hours ago, grannyknot said:
Does the Sivermine kit really have the motor mounted that low?
That was where we installed in her car, here is a picture from their website.  In person you really have to look from below to really see the motor.  When you sit in the car you never see the motor and it is not in the way at all.  I think the picture makes you think it is low but, you really cannot see it easily as I had to crouch down  put the camera below the seat and angle the camera up to take the picture.  I think this is a nice power steering setup for the early Z cars.
1 hour ago, BLOZ UP said:
You can rotate the motor around to make it fit tighter if there's room.
I found out this the hard way as it torqued itself in front of the brake pedal during an autocross.
What keeps it from doing this? Just a bolt that got loose?
