Plates around bell-housing - racing application
44 minutes ago, clarkspeed said:
More common in drag racing but a good safety measure IF the engine is moved back so far that the flywheel is in line with your feet on the pedals. I've never seen that mod before and not sure you can move it back that far.
hey thanks a bunch! Il just get rid of them then. The engine mounting points are OEM. Appreciate it!!
Link to post
I did something similar with 1/4" steel after 3 different machinists looked at my old AZC flywheel. All three picked it up, looked at it for about 5 seconds, then looked at me and said: "That's cool. Do you have a scattershield?" I think the stuff he was selling after the 90s was better designed. Mine had sharp corner cuts right through the pressure plate bolt holes and nothing was radiused.
Link to post
Speaking of flywheels, my local engine shop turns down L-series flywheels to nearly 5lbs! I am tempted since it would be much cheaper than buying new, but honestly I am not confident they have done the engineering or testing to confirm it will hold-up. I saw three leaving their shop on Instagram. Might be OK for the street, but who knows if anyone has ever put one through its paces. it would be quite dramatic if it failed.
Link to post
Takes 5 lbs off, OK. Turns a 25 lb flywheel down to 5? I don't think so, but I certainly wouldn't run it if they did. If you really want lightweight, get a button clutch that has a smaller diameter multiplate clutch on an automatic flexplate. Here's the dual 7.25" clutch I've got on my LS. IIRC the flexplate and clutch and everything was right around 20lbs.
Link to post
Russ_at_steves is the IG name. Steve’s machine shop. Guys, I may have totally read it wrong LOL. @JMortensen you may be totally right about losing 5lbs, not ending up with 5lbs. I attached a screen shot. That’s what happens when you jump to conclusions. It does seem illogical to cut 75% (vs 25%) of the weight just from turning.
Link to post
The lightest you can get, I'd go steel if possible, and with the least mass around the edge of the wheel. You see some with holes around the perimeter. That is the way to go, as removing mass from the edge is more important than in the middle. When you go light you do have to be good about not putting too much heat into the flywheel, so if you have bad habits, you'll want to get rid of them before you ruin your new part.
FWIW the AZC one was 12 lbs, I drove with a heavy pressure plate and cammed L28 with 44s in traffic, was easy to drive. I think the crankshaft itself is so long and heavy that the flywheel weight isn't as important. Had a friend with an AL flywheel on his cammed L18 with 44s and Datsun Comp pressure plate (VERY heavy), and that thing was hard to get moving. He got used to it, but I stalled it a lot whenever I drove it.
Link to post
Posted (edited)
Your points make total sense from a rotational inertia perspective 👍🏽.
I feel like the lightened flywheel is a double-edged sword with a lopey cam (benifit outweighs the drawbacks). I don’t have the experience so I’m just surmising.
on one hand, with a big cam like the one I have (320dur, .500lift) a lighter flywheel may make the lower RPM’s more unstable to maintain on/off throttle. On the other hand, the poor torque in the lower RPM bands will benifit from lower rotational inertia, by reving into the torque band sooner. Although, if you are keeping the rpm’s from dropping too low (consistent downshifting), the unstable lower RPM band becomes Mut.
What are your experiences with that? I’m still working on chassis work so don’t have her running yet. Getting closer every day.
Edited by AydinZ71
Link to post
I used to street drive a 10 pound flywheel with no problems.  I personally think it has a lot to do with you set the bite point where the clutch hooks up and this can vary widely between pressure plates.  That requires some fiddling between master and slave cylinder pushrod lengths.  This isn't so much a problem for the inline 6 because they make decent torque off the line.  It also depends on clutch disc material and if it has a sprung clutch hub.
Link to post
I had a .490/280 cam and wanted to step up to something like you have but ended up LS swapping instead. I love almost everything about the way lightened flywheels work. Revs drop faster so it will shift faster as a result, much easier to heel/toe, engine braking is better, acceleration is better. 2 complaints you'll hear about them is that they make it hard to hold a consistent speed on the freeway, and the trans will probably sound like it has marbles in it at idle in neutral. I never had a problem with the freeway thing at all, and the marbles thing is irritating, but worth it. I've read that it's the gears in the trans rocking back and forth because the flywheel's smoothing of the power strokes is diminished. I had a friend that was really bothered by the noise, and she had the HKS 10 lb flywheel. Seemed a lot more noticeable in her Z than mine, not sure if that was because of engine or trans mounts or different interiors or what.
Link to post
I guess one question is how low RPM do you plan to drive?  When racing I'd think most of the time you'd be above 2500-3500 on the low end and a light flywheel will be helpful.
Link to post
Oh I I’ll likely be driving between 5-7500rpm with this head. Il just need to get used to getting back into that range if I drop off for some reason. This is my first long duration cam so it will take some getting used to.
Link to post
To affix aluminum plates to the transmission tunnel, as a completely new feat for me.  Isn't the more common approach a "blowproof" bellhousing?  Something like this: https://www.holley.com/brands/lakewood/products/drivetrain/bellhousings/ .  These are unfortunately very heavy (maybe 40 lbs), but aren't they required by the NHRA?
Link to post
possibly. I didn’t see anything in the rule book about it for SCCA production or general spec. As someone mentioned, it’s more commonly found in drag racing with dangerous amounts of torque.
Link to post
