jessejames Posted May 30, 2021 Share Posted May 30, 2021 (edited) Hello, so I'm starting a new project. I'm pulling the Sr20det out and swapping in a Honda K24A2 turbo engine into my 1973 240Z. This is a list of the basics: 2006-2008 Honda k24a2 2.4L vtec Cd009 Nissan 370z transmission Efr8474 twinscroll turbo Haltech elite 1500 Ecu. This is my first attempt to do a build log. Edited May 30, 2021 by jessejames Quote Link to comment Share on other sites More sharing options...
Exposed Posted May 30, 2021 Share Posted May 30, 2021 Excited to follow the build! Any pictures? Quote Link to comment Share on other sites More sharing options...
jessejames Posted June 11, 2021 Author Share Posted June 11, 2021 Nothing to exciting to report. I've attached a picture of the new turbo, intake manifold and brake kit. The picture with the sr20det is how it sits. That motor should be out by the end of the weekend. Quote Link to comment Share on other sites More sharing options...
jessejames Posted July 6, 2021 Author Share Posted July 6, 2021 Not a alot of progress. Dry sump kit is missing pulley. Hopefully will here back from the vendor soon. Some pictures of assembled motor to make motor mounts. Quote Link to comment Share on other sites More sharing options...
jessejames Posted July 7, 2021 Author Share Posted July 7, 2021 Trying to mount engine and transmission. Using the apex engineered for the transmission mount. The dry sump pump is making contact with the cross member. The transmission is alittle lower than I like. Quote Link to comment Share on other sites More sharing options...
jessejames Posted July 10, 2021 Author Share Posted July 10, 2021 Engine mounts made, just need to adjust one. Need a spacer for the oil pump. Transmission is now sitting in better spot. Quote Link to comment Share on other sites More sharing options...
jessejames Posted July 21, 2021 Author Share Posted July 21, 2021 Quick update: U joint had to be added to steering shift to fit around motor mount. Turbo manifold is done. Bolt for the crank pulley is too long to fit the ati dampner. Quote Link to comment Share on other sites More sharing options...
heyitsrama Posted July 22, 2021 Share Posted July 22, 2021 I wonder if the frame will flex on load and cause the steering intermediate shaft to bind…. Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted July 22, 2021 Share Posted July 22, 2021 Looking good! I think the K24 setups in a Z is a great option honestly. Great power with light weight. @heyitsrama this specific section of the subframe does not flex a whole bunch under torque. The nearby tie rod mounting box is the thickest steel on a Z. If it does bind, if blame steeper angle on the steering linkage. Ask me how I know so much about the subframe 🤣😂. I have rebuilt this whole section of the car in new steel. you do make a good point though, the whole subframe should be reinforced and/or a roll cage added for rigidity. Looks like this setup will produce at least 300ft-lbs which is where I feel the stock frame starts to flex too much. Quote Link to comment Share on other sites More sharing options...
jessejames Posted July 22, 2021 Author Share Posted July 22, 2021 I will look into reinforcing it further. I have some done. I've got a welded rollbar at the rear, and brace on the front struts. I'm just waiting on the fuel rail, clutch, spacer for dry sump, and few other things. In terms of power. Similar engine with same turbo was making 600whp. I'm planning on running less. 1 Quote Link to comment Share on other sites More sharing options...
heyitsrama Posted July 23, 2021 Share Posted July 23, 2021 I've been eyeballing k24's as a potential swap if my current motor goes out the door. Seems like a great platform. Why the dry sump? Just because you can? or does it help with clearance? Quote Link to comment Share on other sites More sharing options...
heyitsrama Posted October 13, 2021 Share Posted October 13, 2021 http://www.speedhunters.com/2021/10/k-powered-party-front-party-back/ Saw this project online then was thinking about this Z, any progress? @jessejames Quote Link to comment Share on other sites More sharing options...
jessejames Posted October 24, 2021 Author Share Posted October 24, 2021 South Bend clutch and new injectors have arrived. The shop is a little swamped with cars, but I should back in very soon. I was hoping to get it done before winter, but I think the new goal is to be road ready before spring. Why the dry sump? Just because you can? or does it help with clearance? I went with the dry sump as the k24 is a very tall engine, and I was concerned about the oil pan hanging out of the bottom of the car. I thought about trying to make a custom oil pan, but went alittle blingy. Hopefully I'll have more updates in the next month. Quote Link to comment Share on other sites More sharing options...
A to Z Posted December 1, 2021 Share Posted December 1, 2021 It owuld be really nice if you can pull the engine one more time and take the time to paint and detail the engine compartment and the engine and then re-install. Quote Link to comment Share on other sites More sharing options...
artzm Posted January 23 Share Posted January 23 Hi can you send some info on the way you’ll be doing the wire harness and engine management, I’m doing exactly the same set up k24a2 with CD009 thanks Quote Link to comment Share on other sites More sharing options...
