JTR 350 swap harmonic balancer
Going through my JTR manual, page 3-3, it says I'll require a 7.25" or smaller harmonic balancer. Cool. It negelcts to give any part numbers.
I'm about to do the timing chains, gears, cover, and finally a harmonic balancer.
FIRST: What balancer did you use in your swap?
SECOND: did the timing mark line up with the stock timing indicator?
I have searched high and low for an answer to no avail.
Thank you in advance.
10 hours ago, jhm said:
I’ve used the stock balancer on a couple of swaps; currently using this one on current swap:  https://www.summitracing.com/parts/SUM-161350
No, the timing marks have never been accurate for me.  I have always measured it mechanically and adjusted the marks as necessary.
My stock balancer is 8". I was hoping there was an OEM balancer from the 60's / 70's that was 7.25 or smaller. Thanks though, that one is a great price
  • Like 1
