Trouble on initial starting..please help
Hey guys,
Own a 78 280z. I am having the issue of a "cold start", when its not "cold".
Whenever I want to start the car initially for the day, it takes me 4-5 good rounds of cranking to get her going. This happens at any temperature outside. I feel like the fuel pump may be shutting off once I begin cranking?
Any ideas what may be causing this?
Thanks in advance!
The suggestions about the pump are good.  But your symptoms sound a lot like pressure is bleeding off overnight.  Do you have a factory FPR or aftermarket?  The typical aftermarket regulators all bleed down quickly.
You can check all of the possibilities by attaching a fuel pressure gauge and watching it.
If you are able to rule-out fuel pressure, try checking/replacing your ignition system consumables and replacement parts. Cap, rotor, plugs, wires, coil. Check your ignition timing to make sure it has not wandered.
in my case, most times I have had poor cold-start was because my Spark had weakened or become inconsistent. This is most obvious when the car is cold. Once she is up and running, a poor/inconsistent spark can improve as the ignition parts and plug warm.
Thanks for all the suggestions guys. Newzed, I have an aftermarket FPR, without a check valve currently. I suspected this may cause an issue, but I always allow 30 seconds(ish) before cranking for the pump to prime. Other than that, ive replaced all senors related with NOS and adjusted timing/replaced cap rotors ect (she runs great when I get her going).
