Need drivers door patch panel
My 1976 280z driver's door has a unpullable dent at the top right where where the mirror bolts to it.  It's in an extremely tight location and I don't think I can pound it out.  Wondering if anyone has a rusty door that they could cut out a patch panel out of.  I *think* any year 240-280 should work but not 100% sure.
Edited by fusion
Link to post
  • fusion changed the title to Need drivers door patch panel
  • 3 weeks later...
Just an FYI, depending on how big a patch panel you intend to use...the early year doors have the hole for the door lock knob in a different location than the later year cars.  Not a big deal; nothing that can’t be worked around.  Just wanted to let you know so you aren’t surprised.
Link to post
Have you performed any metal work yourself? That little area doesn’t look to bad. I bet you could fabricate a replacement with a sheet of 20-gauge steel, hammer+dolly, and MIG welder. It won’t be perfect, but even a replacement section from another car won’t be. You will still need a small amount of filler or glaze prior to paint. Very few people can perform a flawless steel patch in a contour without any filler of any sort (even if just primer). Try hammering out a little piece yourself in a bench and see how she looks!
Link to post
Thanks man, good info.
Link to post
I have done patch panels before.  I could probably make it but not worth the time to me when I can just buy a panel that's already in the perfect shape.  (I did already get a patch and welded it in)
Also, not sure why anyone would attempt to make a patch without using any filler unless you're working on a DeLorean.
Edited by fusion
Link to post
@fusion nice! Looks good.
so there is an alarming trend whereby folks “freak out” over using filler. Probably because there are some hack jobs out there with 1” deep spots. I think it’s impractical to attempt a steel repair without SOME kind of filler. Sounds like you are practical guy, and we’re on the same page.
Link to post
Thanks man.  Definitely.
Link to post
