R200 3.54. 3.70 close ratio 5 speed, z32 5 speed
Willflow
I have 1 set of US tails in fair shape 100 and 1 set of US tails with loose lenses. 40.
 I have 1 short nose r200 that is 3.54 vlsd. They may be from Q45's. 150 each. I have 2 long nose R200 that are 3.70 gears open carrier. 300 each. 1 1982 280zx " close ratio " 5 speed. 800
1 1990 NA 300zx 5 speed. 700 1 280zx distributor in great shape.. 150.
I have 2 used windshield seals that are probably aftermarket. 40.
Also have a set of used gauges from what I was told are from a 78. I need to find out what they are worth since I don't know if they work.
I have the side board set for the back of a 77, 78. Free.
I am in AZ 86314. All prices are plus the ride.
Edited by Willflow
Add items
Your prices seem pretty reasonable to me.  The Euro-style tail lights are particularly desirable, IME.
If you haven't yet done so, I would advertise them on ClassicZcar.com and the S30 pages on FB.
The diff prices are very reasonable. Trouble is, it may be that most folks don’t want to fork the money for the unique/custom mount, CV shafts, driveshaft, etc. When folks are so inclined, they seem to be going the Ford 8.8 route. I did on the street Z (not installed) since Wlad sells everything except the diff and the driveshaft for a pretty reasonable price.
True. I plan on putting a vlsd Into a longnose 200 myself. I think I can use the 5 bolt n/a z32 stub axles, short pathfinder shafts and custom weld on adapters. If it works I will do a write up but I'm a ways away from it. It would also be the cheapest setup going.
  • 4 weeks later...
  • Willflow changed the title to R200 3.54. 3.70 close ratio 5 speed, z32 5 speed
