titanvein Posted November 3 Share Posted November 3 I've been working on stainless exhaust fabrication and wanted to compare notes with people who have actually built and lived with these parts, rather than just looking at datasheets. A few things I keep running into: 1. Wall thickness vs. heat cycling Going thinner saves weight and helps with tight packaging, but the weld HAZ seems to be where cracks start on parts that see repeated heat cycles. Where do you draw the line between 1.5 mm and 2.5 mm wall for a part that sits close to the turbo or manifold? 2. Back purge on SS304 Full purge gives a clean root, but it's awkward on complex multi-piece sections. Has anyone had good results with solar flux or a partial purge on the inside of joints that won't be visible? 3. Heat shielding Standalone shields vs. wrapping vs. coating — I'm interested in what actually holds up over a few seasons instead of what looks good on a fresh build. 4. Flange flatness after welding Distortion at the flange is the thing that quietly causes leaks and re-work. Do you fixture the flange before welding, machine it after, or both? I'm asking because I'd rather build around what people have actually seen fail than around theory. If you've got photos of failures or fixes, even better — those are more useful than opinions. Happy to share what I've run into on my side as well. Quote Link to comment Share on other sites More sharing options...
flatout Posted November 3 Share Posted November 3 what is the final use of the combo? I wouldn't use 1.5mm a header/manifold for anything other than a dedicated drag car. I'm not a full time fabricator, but I've made a hand full of turbo manifolds with pretty good success for street cars over the years and my experience is I choose sch 10 pipe. (.109 or 2.75mm wall),But I choose 321 not 304. I have used SCH40 304 (~.140" or 3.5mm wall) but I don't think that is necessary unless your looking for extreme structure and weight is no concern. 321 seems to hold up better over time than 304. I've also probably gotten better at welding over the years but I have had two 304 manifolds end up cracking at the wastegate/collector after about 10 years and two 321 manifolds still holding strong. But i also have a handful of 304 that didn't crack. (at least not yet) I recently just made one for my Z out of 321 based off that information as well. As far as back purging. Id say for a manifold its 100% necessary. Its always a pain in the butt and I'm not sure what the best technique is. I do use solar flux regularly on larger diameter pipe like downpipes, turbo backs, or turbo cross overs for V8's with good success too. I feel those structures don't see quite the extreme stresses that a manifold does so i don't know if its as good as back purging. I would say if you can't backpurge then solar flux is the next best thing. as far as flange warping. you need to bolt it down to some sort of flat fixture for all welding. i've had a few that still bow a little and need to be sanded/milled flat but usually if you have it bolted down it holds up fairly well. After the turbo I use .065 (1.65mm) 304ss for the first elbow of the downpipe and have never had an issue. street, drag, drifting or road racing. back when i drifted i would cook ceramic coating off at the collector. I do think some people have good success with it tho so maybe an installation concern. but other wise i header wrap everything. and use a quality turbo heat blanket and heat sleeving around anything important. A master cylinder requires a shield for more organizations. 1 Quote Link to comment Share on other sites More sharing options...
titanvein Posted November 4 Author Share Posted November 4 On 2026/11/3 at PM8点15分, flatout said: 这套组合的最终用途是什么?除了专门用于直线加速赛车之外,我不会将1.5毫米的排气歧管/排气头段用于其他任何用途。 比较汽车 我不是全职的金属加工师傅,但这些年来我为街车做过不少涡轮增压歧管,效果还不错。我的经验是,我会选择 Sch 10 管径(0.109 英寸或 2.75 毫米壁厚)的管材,但我会选择321而不是 304。我也用过 Sch 40 304 管径(约 0.140 英寸或 3.5 毫米壁厚),但我认为除非你追求极致的结构强度且重量不是问题,否则没必要用那么厚的管材。321 管材似乎比 304 管材更耐用。这些年来我的焊接技术可能也有所提高,但我有两个 304 管径的歧管在用了大约 10 年后,废气阀/集气管处出现了裂纹,而两个 321 管径的歧管至今仍然完好无损。当然,我也有一些 304 管径的歧管没有出现裂纹(至少目前还没有)。最近,我根据这些信息,用 321 管材为我的 Z 车做了一个歧管。 至于回流吹扫,我觉得对于歧管来说,它是绝对必要的。回流吹扫总是很麻烦,而且我也不确定最佳方法是什么。我经常在大直径管道上使用太阳能通量清洗剂,比如排气管、涡轮后段排气管或V8发动机的涡轮交叉管,效果也不错。我觉得这些结构承受的应力没有歧管那么大,所以我不知道太阳能通量清洗剂的效果是否和回流吹扫一样好。总之,如果不能进行回流吹扫,那么太阳能通量清洗剂就是次佳选择。 至于法兰翘曲的问题,焊接时需要用螺栓将其固定在某种平面夹具上。我遇到过一些法兰翘曲的情况,需要打磨/铣削平整,但通常情况下,只要用螺栓固定,它就能保持相当好的状态。 涡轮增压器之后,我使用 0.065 英寸(1.65 毫米)厚的 304 不锈钢管作为排气管的第一个弯头,从未出现过问题。无论是街道行驶、直线加速赛、漂移还是公路赛。 以前我玩漂移的时候,会把排气歧管上的陶瓷涂层烤掉。不过我听说有些人用陶瓷涂层效果不错,所以这可能跟安装有关。除此之外,我一般都会用隔热带包住排气歧管,并在所有重要部件周围使用高质量的涡轮隔热毯和隔热套管。主缸还需要额外的隔热罩。 That’s a fair point — I wouldn’t use this 1.5 mm Z-pipe as a primary header or turbo manifold either. The intended use is downstream custom exhaust routing, where the main problem is packaging around existing components rather than supporting the turbine or collector. In that position, 1.5 mm stainless is a very different application from a manifold seeing direct turbine heat, concentrated collector stress and repeated flange loading. The part is mainly useful where two pipe paths need to cross in a compact space. The printed junction gives a controlled internal divider and repeatable geometry, but it does not remove the need for proper support, purge welding and a good transition to the connecting tubes. I agree with you on the manifold side: 321 and a thicker wall make much more sense for long-term durability, especially around the collector and wastegate. For the Z-pipe, I would still treat the actual vehicle, heat exposure, unsupported span and hanger layout as the deciding factors rather than claiming that 1.5 mm works everywhere. Also agree on back-purging the manifold. Solar flux can be useful when purging is difficult, but I would not treat it as equivalent on a highly stressed turbo manifold. Fixture the flange during welding, control the heat input and check it flat afterwards — that is usually more important than the material debate alone. Your point about ceramic coating and heat shielding is also well taken. On a street or competition car, shielding the master cylinder, wiring and nearby components is often more valuable than relying on the coating to survive indefinitely at the collector. 1 Quote Link to comment Share on other sites More sharing options...
