coilovers
I recently acquired a set of Ground Control coil overs. I need to cut out the perch and weld in a stopper for the threaded tube to sit on.
My question is, is the strut assembly fixed to the brake assembly, etc. permanently? I want to swap to rear discs later when I find more money and I don't want to have to cut out the stopper ring again when I do.
Or can I find a newer Z with rear discs and swap the entire suspension in, having welded the ring for the coilovers?
Thanks,
Owen
http://www.homestead.com/s30z/index.html
