Wideband for SDS, LC-1 or LM-1
BayAreaZT
I understand SDS can now data log from a wideband with a software upgrade but unless I'm missing something, you can't download the data to a laptop for analysis. Ideally, I'd like to make a few runs and go back home to look at the data so I'm looking at picking up a LC-1 or LM-1 but I'm a litle confused between the two.
Is the LC-1 the same as the LM-1 but without the standalone unit? To put it another way, can the LC-1 with a laptop do everything the LM-1 can do? If I get the LC-1 or LM-1, do I need the RPM convertor to log RPM with AFR?
This is to tune a L28et with SDS.
hey man,
I currently have my LM-1 setup to pull data from the sds ecu and datalog it in Logworks.
Both Warren and Pallnet pinned out each sensor to tap into and Pete(Pallnet) sold me a plug and play setup to do this using the RPM converter from Innovate.
this was my #1 complaint with SDS until i went this route, works Great!
Ok, so basically whatever you want to log, you tap into the signal going into the SDS brain? I'm just a little confused because the RPM convertor gives you additional inputs to log more sensors but the description of the LM-1 says this
"The instrument can sample and store 6 channels of data- air-fuel-ratio and up to 5 other sensor data channels...."
Can it sample 6 channels without the RPM convertor? If it can, I don't think I need any additional inputs.
The LM-1 has 5 analog inputs, and the lambda sensor. The 5 extra inputs
is just 0-5v. It logs all 6 inputs.
The RPM convertor uses one of the inputs, and converts rpm pulses
to an analog signal for the LM-1 to use, and gives you connectors to
mount cables for the rest of the inputs.
I bought my LM-1 with the auxbox (LMA-3), and with the built in map sensor
it is perfect for mapping my autronic!
The software presents it in a map/rpm chart, and shows the afr-ratio
all over, and makes it easy to see were to correct.
I would say you should buy the auxbox.
  • 4 weeks later...
Just got my LM-1 with RPM kit last week. Did a few time based test logs and I think I'm really gonna like this product :icon14: . I'll wire the rest of the inputs and do some real logs this weekend.
BTW, I got it on sale here. All the Innovate products are on sale.
http://www.sasquatch-motorsports.com/store/index.php?act=viewCat&catId=80
