ECU light went out
Another problem with my swap (81 zxt -> 240z). I plugged my fuel pump into the lead for switched 12 volt where the fuel pump relay is supposed to go because the relay was left behind when I pulled the engine. When I turned the key on, the fuel pump ran for a second and then stopped. Now, the green light on the ecu doesn't come on anymore.
Is there a fuse or something inside the box that I can change?
