fiberglass cowl induction
zliminator
I'm designing a cowl induction hood. I have the plug ready for acylic primer and then after wet sanding I'll make the mold, the part and then attach the part to the hood and so on, but I'm wondering if I should block off the section of the scoop that is in front of the air cleaner. IOW, I'm going to make ductwork which directs air from the rear of the scoop, where the opening is and air supposedly bounces off the windshield, into the air cleaner and carb. There will be some extra space in front of the air cleaner just because I wanted the shape to continue towards the front of the hood for asthetics. See my rough diagram at http://www.hampleman.com/hood.htm. I hope this explains my question.
Dan
