I am looking for an oil pump primer SBC350
I was curious if anyone had one of these lying around from an engine build that they would like to sell. I have an engine that has been sitting for a while and thought it would be a good idea to make sure there is oil flowing in the engine before starting it.
Guest skidpan
dude I have had many times been in the same place as you. I just pull the plugs out and turn it over by hand a bunch, and Ive never had a problem with oil pressure or bearings... I have also squirted a little oul in the cylinders just to get a little lube in them so as not to scratch the cyl walls
Its been sitting for a few years...so I think I should confirm that the oil pump is working before starting it.
this type above is nearly WORTHLESS
this type bellow works just fine
http://store.summitracing.com/partdetail.asp?part=PRO%2D66896&autoview=sku
they are dirt cheap or you can make one from and old distributor
be sure you turn the engine over at least two full turns while applying pressure to and lubing the oil passages to get full access to all the lifters,rockers,bearings etc.
Why is the first one worthless?
"Why is the first one worthless?"
LOOK CLOSELY, the top primer has no collar to keep the drive shaft centered over the pump so it can slightly mis-align and bind, Ive seen them bend the pump drive if guys get them mis-aligned and just throw a high torque 1/2 drill on and spin them without checking, the lower primer has an alignment collar that tends to keep things from breaking,,yes both have the alignment collar for the manifold but only the botom one has the lower block support and alignment sleeve that forms the lower oil passage wall, and the drive collar that assure the oil pump drive itself is lined up correctly,keep in mind,the bottom of the stock distributor forms one wall of the main oil passage to one side of the engine, without that passage wall in place you get no oil pressure to one side and darn little to the other due to the HUGE leak the missing oil passage wall presents, the lower distrib is temporarily replaced with that extra aluminum on the lower primer to simulate the correct oil passage config....THATS WHY!
LOOK CLOSELY, the top primer has no collar to keep the drive shaft centered over the pump so it can slightly mis-align and bind, Ive seen them bend the pump drive if guys get them mis-aligned and just throw a 1/2 drill on and spin them without checking, the lower primer has an alignment collar that tends to keep things from breaking,,,,,the bottom of the stock distributor forms one wall of the main oil passage to one side of the engine, without that passage wall in place you get no oil pressure to one side and darn little to the other due to the HUGE leak the missing oil passage wall presents, the lower distrib is temporarily replaced with that extra aluminum on the lower primer to simulate the correct oil passage config....THATS WHY!
Ok...Dont have to yell! Thanks though...I guess you are grumpy :)
Im not yelling trust me!
I never yell,
my 25 and 33 year old kids will tell you, that, yeah I get grumpy, but I don,t yell, I tend to talk slowly and clearly when Im making a point, but I don,t yell.....my kids know its time to take a break or disappear at times but they,ve very rarely heard me raise my voice for any reason, the typing of capitals is only meant for clearity and to make a point
I never yell,
OK gotcha...thanks for the advice and info. You dont happen to have one you want to get rid of do you?
no, but at less than $20 I can,t see anyone not buying one new for thier personal tool set
btw heres a basic tool list, (no I don,t have everything YET but IM getting much closer..)
A set of quick release tools for late model gm fuel lines and a/c line disconnects.
ACETYLENE TORCH
ADJUSTABLE LENGTH PUSH ROD
ADJUSTABLE POINTER ,
Adjustable stand, for dial indicator
Assorted pliers/vise grips
Air compressor
Air ratchet
Allen wrenches
ASK QUESTIONS
ASSORTED FILES
ASSORTED SOCKETS,OPEN AND BOX WRENCHES 1/2",3/8".1/4" DRIVE
Ball joint press tools
Ball joint separator forks
Battery charger(full size shop type)
Bench grinder w/ wire wheel
Big huge screwdriver which doubles as a pry bar
BORE GAUGE
Brake spring pliers and retaining spring tool
CAM BEARING INSTALLER
CAM DEGREE WHEEL
CAM HANDLE
CARBIDE BURRS
CC Buret Kit/PLUS STAND
Checking springs
chisels (assorted sizes/types)
clamp for compressing calipers
CLUTCH PILOT
Coil spring compressors
Compression tester
COMMON SENSE
CRANK SOCKETS
Creeper
Crows feet wrenchs
CYLINDER HONE both 280 and 400 grit
DENT PULLER
DEPTH GAUGE
Dial indicator, and stands
Die grinder
Differential Set-up Kit
Distributor wrench
DRIFT PUNCHES (assorted sizes/types)
Drain pans all sizes
Dremel tool set to cut rivets etc.
DRILL PRESS
Drop light (florescent preferred)
Dwell meter for the older cars
EASY OUTS
ELECTRIC SOLDER GUN
Electrical tape
Engine hoist/crane
ENGINE LEVELER with swivels
ENGINE STAND
Feeler Gages
FIRE EXTINGUISHER
Flexible dwell key for point distributors
FREEZE PLUG INSTALLER
FUEL PRESSURE GAUGE
Full set of assorted hammers all the way up to 5 lb hand held full set of tap and dies metric and standard
Full set of torqze tip screw drivers and sockets male and female all sizes
Full size vice
Gasket scraper
Gear Pullers
GM disk brake caliper Allen key 3/8 and 5/16
Grease gun
Harmonic balancer puller
HARMONIC BALLANCER INSTALLER
HONING STONE
12 ton Jack stands (4) minimum)and a 2 1/2 -3 ton full size service floor jack
JEWELERS FILES
LAPTOP COMPUTER
Leakdown tester
LIFTER BORE HONE
LIFTER GROOVE TOOL
LUIS TOOL
Magnets (several)
MAGNETIC PICK UP TOOL
MAGNIFYING GLASS
MANUAL LUBE PUMP
MICROMETERS
MIG WELDER
Mini Valve Spring Tester
MIRROR
modeling clay (2 lbs)
Multimeter (both analog and digitay types)
Normal screwdrivers all sizes & type
NUT SPLITTER
number stamps in 3/8" and 1/4" sizes
OIL CAN
Oil filter and regular spin on filter wrenches.
Oil filter wrench
Oil Pump Primers
ONE NEW SOLID LIFTER
PB BLASTER OIL
Pipe cutter
PISTON RING COMPRESSOR
Piston stop,
Pitman arm puller
Plasma cutter , at least 150 amp
PLASTIC HAMMER
Pneumatic chisel
Pneumatic impact guns 3/8 and 1/2 drive
Pressure bleeder for brakes
PRY BAR
PUSHROD CHECKER
Putty knife , 2" and 4"
Ramps (oil change type at least 12 high)
Rear caliper piston turning tool
REFERENCE MANUALS
RIFLE CLEANING ROD AND BRUSHES FOR OIL PASSAGES
Ring expander pliers
RING GAP FILER
Rochester idle mixture adjusting tool
ROD BOLT GUIDES
ROD BOLT STRETCH GAUGE
SELF DARKENING WELDING HELMET
SCAN SOFTWARE
Sledge or mall hammer
SMALL FLASH LIGHT
Snap ring pliers internal and external
SPRING COMPRESSOR
Standard set of drift pin punches,alignment punches,[censored] and centering punches.
Steering column lock plate compressor
Steering wheel puller
Stethoscope
STUD INSTALLER
TAPE MEASURE
Test light
Three or four of every type and size socket and wrenches in both metric and SAE
Timing light, (advance type )
Tire Pressure Gauges
TORQUE WRENCH (at least two)
torx bits, both long and short, sizes t-10 thru t-50
Transmission jack
Tubing cutter
Tubing flare tool
Tubing bender
Utility knife
VACUUM GAUGE
Wire crimper
Wheel chocks (keep cars from rolling)
GOOD KNOWLEDGEABLE FRIENDS
Other things to keep handy - TheBandit
Additional items that may come in handy -
Gasket scraper
Plasma cutter
Drill press (stand alone)
Allen wrenches
12pt sockets
Deep sockets
Impact sockets
Compressor
Retracting extension cord
Safety glasses
Die grinder
Wire crimper
Valve spring compressor
Breaker bar
Distributor wrench
Taps & dies
Oil filter wrench
Line wrenches
Crows feet
Shorty wrenches
Tire iron
Cutting torch
FIRE EXTINGUISHER
Throw-away vinyl gloves
Plastic zip-lock bags
Permanent marker
Duct tape
Electrical tape
Torque wrench
Oil pump primer
Speed wrench
Carburetor stand
Tire pressure gauge
Compression gauge
Sandblaster
Paint gun
Utility knife
Transmission jack
Mallets , lead, rawhide and rubber
Stethoscope
ACETYLENE TORCH
Air compressor
Air ratchet
Allen wrenches
ASK QUESTIONS
ASSORTED FILES
BORE GAUGE
CAM DEGREE WHEEL
CAM HANDLE
CARBIDE BURRS
Checking springs
CLUTCH PILOT
Compression tester
COMMON SENSE
CRANK SOCKETS
Creeper
Crows feet wrenchs
DENT PULLER
DEPTH GAUGE
Die grinder
Distributor wrench
DRILL PRESS
EASY OUTS
ELECTRIC SOLDER GUN
Electrical tape
Engine hoist/crane
ENGINE STAND
Feeler Gages
FIRE EXTINGUISHER
FUEL PRESSURE GAUGE
Full size vice
Gasket scraper
Gear Pullers
Grease gun
HONING STONE
JEWELERS FILES
LAPTOP COMPUTER
Leakdown tester
LIFTER BORE HONE
LIFTER GROOVE TOOL
LUIS TOOL
Magnets (several)
MAGNIFYING GLASS
MANUAL LUBE PUMP
MICROMETERS
MIG WELDER
MIRROR
NUT SPLITTER
OIL CAN
Oil filter wrench
Oil Pump Primers
PB BLASTER OIL
Pipe cutter
Piston stop,
Pitman arm puller
PLASTIC HAMMER
Pneumatic chisel
PRY BAR
PUSHROD CHECKER
REFERENCE MANUALS
RING GAP FILER
ROD BOLT GUIDES
SCAN SOFTWARE
SMALL FLASH LIGHT
SPRING COMPRESSOR
Stethoscope
STUD INSTALLER
TAPE MEASURE
Test light
Transmission jack
Tubing cutter
Tubing flare tool
Tubing bender
Utility knife
VACUUM GAUGE
Wire crimper
Gasket scraper
Plasma cutter
Allen wrenches
12pt sockets
Deep sockets
Impact sockets
Compressor
Safety glasses
Die grinder
Wire crimper
Breaker bar
Distributor wrench
Taps & dies
Oil filter wrench
Line wrenches
Crows feet
Shorty wrenches
Tire iron
Cutting torch
FIRE EXTINGUISHER
Permanent marker
Duct tape
Electrical tape
Torque wrench
Oil pump primer
Speed wrench
Carburetor stand
Tire pressure gauge
Compression gauge
Sandblaster
Paint gun
Utility knife
Transmission jack
Stethoscope
Yeah I have all that...just missing the oil pump primer
if your serious about the hobby and have been as envolved as Ive been for over 40 years youll be close to having most of it....the plazma cutters and the 300 amp tig welder are next on my list
I also want to get a TIG for aluminum...and a plazma cutter...so many awesome tools ....so little money :)
  • Administrators
I performed the old distributor modification that Grumpy mentioned. I found an old dizzy in the U-pull yard a few years that had good bushings, spent a little time on the lathe and wa la.
"I'd hate to see the advanced tool list."
yeah! it gets depressing when you see the costs
http://www.radautomachine.homestead.com/Rottler_HP6A.html
$35k for a cylinder hone
then theres crank ballanceing machines
line hones
hydralic cylinder presses
sonic testers, lathes
mills
decking mills
magnaflux and zyglow testers
sonic parts cleaners
ETC.
you could $pend a couple million DOLLAR$ and not have nearly a full equiped engine shop!
