Should I?
Guest TDMCobra
oh yea just make sure you get a car thats pretty solid (ca car something). If not chances are the floor pans and frame rails are shot so you would have to go through the time (and money) of changing those. And if your not doing them your self cost goes up some more. like others said, if your pretty handy and can work on the car your self it will be worth it. Its saved me a ton of money.
Guest TDMCobra
just found a 77 280z at my local salvage yard with clean title not salvage title you could pick up cheap under 500 my guess. i just got a 98 ford for less from him
How close is Port Neches to Austin? Rust?
Guys, thanks for all of your help! Im pretty much settled on fixing the mustang and then using the leftover $ to start a 240z swap. I should settle today so well see how it goes...
