sr20det intercooler question
280zjoel
ok, so im doing an sr20det in my 75 280z and i'm doing a similar setup as Alex's top mount 240z from vildini motorsports. (mines a little more mickey mouse thought:weird:) I had an ubber-noob moment and decided to run a q45 throttlebody instead of the stock sr throttlebody. that being said there is bout 1 to 1.5 inch gap between the throttlebody and the intercooler outlet, is it ok to just use a 3''-3.5'' transition hose to connect the intercooler to the throttlebody? Does anyone think there will be any issues with engine movement causing the hose to tear under load?
HPIM1329.jpg?t=1202157660HPIM1328.jpg?t=1202158582HPIM1330.jpg?t=1202158623
  • 3 months later...
I'm doing a v mount with my SR20 setup as well, but I had more space between the enigne and intercooler than that. I used a transition and a hump hose. I would put the IC more forward if you could. On the other hand You could solidly mount the engine... but this isn't a good enough reason to do that.
where did you get that ic?
i cant find the exact one i got but here is another one ou can use, just make sure the dimensions will fit your car.
http://cgi.ebay.com/ebaymotors/CXRacing-INTERCOOLER-24x11x3-Mazda-RX7-V-Mount-FMIC_W0QQcmdZViewItemQQcategoryZ33742QQihZ013QQitemZ230251862904QQrdZ1QQsspagenameZWDVW
  • 3 weeks later...
