F-54/N-47 , or F-54/ P-79?
s14280zx
I'm planning on building an engine for both of my cars, a 1979 280zx, and a 1978 280z 2+2. I will have a triple weber 40mm setup on the '79, and I was trying to keep the '78 stock looking with fuel injection. I have two F-54/ P-79 engines with under 90,000 miles on them. Would I be better off changing to the N-47 heads raising the compression, or should I keep the P-79 heads on and use them. Would it make a noticable difference between the two compression ratios with fuel injection? Thanks For The Info.
  • Administrators
This exact topic has been covered and recovered around here. Use the search function and search for “L-28 detonation”, etc.
In sort, do NOT put the N-47 head on an L-28 with Flat-top pistons.
You can only increase the compression ratio so far on the L-28 with open chamber heads before detonation sets in, and at that, is VERY expensive as it will cost you a custom set of pistons. At least $600-$800 for pistons not including the rest of the rebuild parts and machine work, all for a mild bump in compression ratio that might net you 5-8 HP? Not worth it my opinion. Better places to put that sort of money for more return in power. Stock flat tops with the Z car N-47 is too much compression for premium pump gas!
Again it is has been covered…
Good luck,
Paul Ruschman
HybridZ staff
I appreciate all the great advice you've been giving me. I have bad luck searching most of the time, and I like to ask questions that are specifically for my application, rather than searching for, and reading numerous threads that may or may not have the info I need. This way saves me alot of time that I can use working on my cars. Thanks for the help.
