Need Help (rough engine.) '79 280zx n/a
Guys,help me.
She's sick and i'm lost.
I'm a kid who win 8.60/hour.I bought her for 1,400.
I don't have many mecanical experience as it's my second car.I know what's a AFM on a '89 camry and how to change some spark plugs.I help my father with his '73 Vw bus.
I want to learn,this is why i've worked 163 hours to buy what makes me lives.Next year I start a mecanical class.I know how a engine work in general,the basics.
I've bought a 280zx with a frame in bad shape,I knew i was going to spend many hours in there and spend 3x her price on parts.Why? cause i like that.I don't know what i do but i love to repair car.So, i bought a gaz boat full-280zx who wasn't running fine in hope to solve the probleme fast and then tune her to 250hp.Today I only want her to Idle,how many power is needed to idle a l28e ? 50lb-ft? So my goal is 50 lb-ft.As i figured out I've spend many cash to repair her.I've change the air/fuel/gaz filter,change the oil.change the fuel pump for a new one (roughly 325 bucks but i didn't looked at the price,i've thinked to my passion)I've putted some suprem gaz,changes the spark plugs and valve cover gasket.I passed many hours on her: like testing things.With that time passed on her ,I now know that my fuel pressure is good out the fuel presure regulator as it squirled 2 feet in the airs (where my eye was.)
Now ,guys,I come back here. Yes i've readed the carfiche.com.As i said I'm lost.
1 hour ago I've tryed to check the AFM electricals,But where the f**k are those pins ? in the ecu ?dont have any detail except ''+ in pin no 36''
Okay enough for the lil' emotive story As some saw ,I speak french and it's not really easy for me to exprime clearly what i do.So,i will go straight ahead.
after i've changed the valves cover gasket sshe was running much finer than when i bought it.but a week later she started to loss power and backfire (exhasut and some time trought intake)
You guys know what i did to my car from the last posts.The only thing not writed is that i've change the fuel pump,test the fuel pressure regulator(o.k.).I've focused on the fuel system in facts.
Now the ZX can't reach idle anymore. She turn on the starter then run without the starter (by himself) But only at 300 tr/min.pressing the gaz pedal don't help.
I dont have air leak(at least i did't saw one).I have fuel (at the regulator) and i got sparks.(tested) And i Do have air(afm).(tested/removed/cleaned/played with it)
So what's left ? injector (rebuild/109$ each/new= 179$ ouchh) I saw the connector are in bad shape: they are really easy to remove and i got ( idont know the name in english) green rust in there.The guy who had it before changed two (2) injectors.Are the 4 left dead? It's the only thing that could fail for fuel issue.
If it's not that,it's a electrical probleme,as the 30 y-o ecu.
So guys help me.Say anything.say that i'm gay ,that my engine is blown ,order me to test anything,If it's not absolutly ridiculus I will do it.I want her to run.I maybe don't have many cash but i can buy almost anything if you give me time and if your sure it worth it.I thrust you guys.I can test/remove/clean anything If i need too.I want to learn. give me a way to go.Anything.
Please give as much as possible details.It's not my 10th Z and don't know everything of them.but a know what is an ecu,connector etc.I got a wrench and i multimeter(etc).
So give me something to test.
Thanks
Gracias
Merci
Blacktools
  • Replies 42
Hey, he tried and I think I can get the jist of what he is saying.
Blacktools, get some electrical contact cleaner and try cleaning up the corrosion (green rust) on your injectors. It sounds like they aren't getting any power. Also clean the plugs that go to them too.
Let us know if that fixes the problem ;)
exactly,Woldson: Oh Boy !
I've cleaned 4 injector connectors (fault of time) and it fired up at 1000 tr/min...then slowly died.
Tonight i will clean again the 4 injector and clean the 2 others too.
really starts to sounds like it's the connectors.:P
I will give you an update tomorrow.
Blacktools
Okay,
I've cleaned every injector connectors with contact cleaner and brushed them to remove the corrosion.
The dry plactic ''holder'' (what holds connector in place) are cracked and don't do ther job well but they (connector) are all in place well connected tought.
The ZX didn't fired up..in fact she did but ,as always, died.
I've saw that the 1st time i fire her up she always reach 1000 r/min and the other times juste go to 750 max.
I've spotted something that may help us.When i fired her up...the first seconds she smokes white the when she run without the starter she smokes black...
Is this a sign that she runs very rich (or poor)?
could a bad timing cause cause that?(can i check it out myself?)
can it be the thermoswitch or cold start thing ?
If i dont press the gaz pedal a liltle she dont reach 200 r/min (dont run without the starter)
THANKS GUYS
blacktools
Throw another valve cover gasket at it? Sorry, couldn't resist.
Black or white smoke = possible head gasket problem.
Lack of power, barely idles but does fire = possible head gasket problem
Lots of other stuff wrong, but you need more help than you can get on a forum. You need someone showing you the ropes. Find a friend, or rent one off of Craigslist.
Good luck,
David
yhea you'r not wrong...the block look oilly.
My mecanic come back from vacancy in 1 week.
I will go see him and if he dont find i will have to go at Nissan delear ship.
and yhea,I,ve trown a new valve cover gasket....he was srap...oil was barely sinking by there...
thanks guys anyways.
blacktools
took the compression again.
26 july___ 2 weeks ago___ diff
1 __120 .... 1 __ 135.........15
2 __135 .... 2 __ 140 ....... 5
3 __135 .... 3 __ 145 ........10
4 __125 .... 4 __ 125 ........0
5 __130 .... 5 __ 140 ........10
6 __125 .... 6 __ 140 ........15
It was a long time ago.Arround 2008,a cloudy day and a boy.
that boy owned a 280zx named the ''Z''.She wasn't runing anymore.
that boy,named blacktools,had do some research on HybridZ on what could cause a engine to run really bad.He did ask a mecanic too who answered him a fire probleme
.So the kid got out of his house,went in the Zx ,poped-up the hood and started to look at any electrical wires.He already knew that many of them wasn't connected but he didnt knew where the hell they are supposed to go.
The kid found a greenish wire that came out of a sensor just under the radiator tube,near the coil.The other end of the wire was a home a.k.a. ''custum'' made ground.The kid had a feeling: he removed the home-made section of the wire and connected the right wire on a another wire that was coming out of many others.
then the kid boosted the battery.turned the key,pressed the gaz pedal a little.
then the following is only for mature,ready to sream some bad words peoples.
The engine slowly got to 1k r/min with the starter's help.then he pressed the gaz a little bit more.
1500 r/min
1750 r/min
here my pants are half-way full
2000 r/min
2200 r/min
2550 r/min
here they are full.
Oh god,its so good to hear her after about 3 weeks.The exhaust that let the smoke go out anywhere else than by the tip,The shaking movement of the chassi 'cause it surely run on 4 cylinders,the smell of burned oil,gaz,water.
She dont run without gaz pedal at at least 4/10 ,she dies.
she dont go higher than 2800 r/min
she smokes as hell white /grey and liltle black
she sounds like it runs on 4-5 cylinders.
I go at the garage in 2 days.
:icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4::icon4:
HEY !
I went to the garage.
after 1 hour of searching the mecanic found.
The injectors are busted and dont close.So my car was always flooded.
I found i place were the rebuild them for 45$ each.
it worth the try as some rebuilt where i take my pieces sells them 108 $...
the basic says : you need air,spark and fuel....but how much ?
So thanks guys for your help.
as you see.I've learn.
i will still give some update of ''after rebuild injector are in''
and don't worry more plans are to come......and who know ? maybe it's just not the injector !!!! :P
See you arround guys.
(damn,some of you have some really nice project !)
BLACKTOOLS
tonight,i
I have removed the fuel rail and injectors.
if anyone needs pictures; send me a mesage.
tips for a beginer from a beginer:
put some number to everything you dissasamble
work with some light.
take your time.
think before acting
ask help to dad or a friend if you have problems before you trow the hammer in (XD)
Oh ,and when you disconnect some fuel line,don't smoke (!!) and always think where the fuel will go.....(on you?) because i've tried in the past and i can tell that fuel+eye= ouch.
By the way,I plan to ''polish'' (clean up to be shinny) my fuel rail...You recomend or not ? i know it will looks better but i mean in term of durability.
XD
Blacktools
Sorry for any mistakes,correct me if needed.
I went to a injector specialist.
In the L28 I had:
3 n/a injectors pushing the corect amond of fuel. (green connectors a46-00)
1 Turbo injector pushing almost 2x the n/a one.(pink connector ''ram'' (?)
2 hazardus injectors. (black d1560ba)
So, i will buy a new injector,then
install them back (4 green + 2 hazardus black)
and will try to put the 2 black one that i dont know how much they push on different ''stroke''
then if it still run bad i will try to disconect the black ones to see if it run smoother.
NEED HELP HERE.
when i will put the injectors in +fuel rail, should i load(full) them with fuel
before closing all lines to be sure no air left ?
thanks ,Blacktools
Bonjour,
Okay I'll stop with the fractured french.
You sound like you' re having a devil of a time.
This is just a suggestion but if you are fixing/ replacing fuel injectors do yourself a favor and replace all of them with OEM Nissan (I guess Bosch) injectors.
Yeah it's expensive but they last and the cheap ones fail prematurely.
I guess it's like the sign on some mechanics' shops wall says,
"Fix it right once and cry once, or fix it wrong and keep crying."
Something like that I guess..
A bientot!!!
In facts,I dont really care about ''how long they will be okay'' because the frame near the engine is busted,I can remove some piece of it with my Pinki.
So right now i just wanna see if the engine CAN run well,if its really the injectors.
In the middle of the next year i will may change of ride (a older one :D) so i dont want to spend 3k$ on it if its not the injectors.So if with the cheap injector in he runs well,My plans will be to buy a older Z next year (with a clean frame.........)and put the rebuild l28 in there...
But who knows,next year i will be at the 7/10 of my mecanical classes,I will have a better job.My plan will surely changed and as i Always wanted a Silvia but never had the money,maybe it will ends in a Silvia and not a Z.
But one more time,Who knows,Maybe i will find a really nice Z and build it..
or buy a freaking 4 door cavalier cause i wont have time to work on....nha,bad idea. i prefere to have no space ,no time but a fast,clean car.
(her i just realized that older Zs are carb.and mine is Injection=tought to do the conversion.
Anyway.For now i just want it to run before 7 foots of snow fall on her.
dont worry i found a place where she will be in a dry place.
By the way...your french is not so bad...but never use Google for a complet sentence.
Donc je vais vous envoyer des updates dans pas tres long ,environ 1 semaine avec les nouveau injecteurs et tout remit en place.
Translation= So,i will send you a update in arround 1 week with the new injector and everything back at his place.
Cya guys
blacktools
What' up.
I've changed My Turbo injector for a rebuild n/a one.
Still dont run.
I've looked the spark plugs and no 1+2 are wet.(those have some''aftermarket''injectors.If i disconect there injector connector ,It does not changed the engine idle...still run like ♥♥♥♥...but at the same lvl of ♥♥♥♥.
SO those cyl. Dont work...in fact he run in 3 cyl.the 3 with stock injectors(green tops).
