RB Remote Oil Filter Takeoff?
900ss
i have that sandwich. make sure you get one of these
http://www.rawbrokerage.com/RB-Oil-Filter-Stud-Direct-to-Block-nissan-oilfilterstud.htm
i havent gotten around to my oil pressure sender but if it is 1/8npt (not sure but i would assume it is, but assumptions get me in trouble) you could use this
http://www.240sxmotoring.com/1gaad.html
http://ep.yimg.com/ca/I/yhst-1164098593086_2139_66998794
Ahh thanks for your help... I just need the stud... I can get the sandwich plate wholesale elsewhere for cheaper. Also I can get the oil adapter fittings to run the sensors from GReddy as well... The aftermarket 1/8 NPT pressure probe is for my gauges, and the stock oil pressure sensor I believe runs to the ECU.
One last unanswered question... Where does the stock oil pressure sensor bolt to? Does it fit on the GREX sandwich plate?
Edited by 240Z_Master
did you figure this one out? i need to mount my temp and pressure sensors (mainly the pressure). i cant seem to figure out which is best for the pressure sensor.
BTW the oil pressure is 1/8 bspt
i am going to drill and tap my plugs for sensors. i got (2) 1/8 npt to 1/8 bspt from mcmaster for 5 bux each so i can keep everything 1/8 for when i upgrade my gauges.
  • 2 years later...
Is it nessesary to have the oil temperature and oil pressure sensors mounted for the engine to run properly? or is it only realy for using them for gauges? If so would it be possible to mount them after the block adaptor using a T fitting before or midway along the braided line leading to the remote oil filter plate?
Im just finishing up planning out my remote oil filter setup. I found a thread very helpful for remote filter setup. http://www.freshalloy.com/archive/index.php/t-126849.html
Couple of main things to take from that thread are:
Nissan part # 15213-21001 will give you a thread that you can put into your RB block to attach a spin on adaptor to.the thread will look something like this. http://i175.photobucket.com/albums/w129/r25558/RB26Buildup056.jpg
Earl's 1178ERL can be used in conjunction with the above part#
Edited by ///M3 & Z
