alternator
I have been told by people that make harnesses that you need 12 volts to the " L" terminal on the alternator but you must put some resistance in line so as not short it out. This 12 volts will "excite" alternator and turn it on. Keep It clean guys. 350 OHM 1/2 watt resister is what I was told to use, Available at Radio Shack I believe. The 12v should be keyed
i put the resistor in and it started charging , but by the time i went to check the voltage it stopped charging.i tried it 3 diffrent wires with the same results ,so do you guys think i should replace the alternator or rebuild it or what next?
