my diff question
mikesv8z
What has been done successfully is to either fabricate spacers to eliminate the extra tolerance when using 10mm in a carrier designed for 12mm bolts. I may be wrong but, I think your 8mm bolts are actually 10mm. When I installed my Precision Gear LSD unit, I encountered the same question you have asked! Precision Gear's advise was to fab spacers or not. If no spacers are to be used, besure to rotate the ring-gear in the direction it would naturally take when loaded. Be sure to use lok-tite and the proper torque on the ring-gear bolts. There is a write up on this subject in the archives....just search.
Tom
