my 510 with Rb25det
510rb25det
Id like to see a dyno vid of the car actually making 600whp on the rollers. Regardless whether or not is has 600whp, how do you even produce those numbers on the dyno in such a light car without smoking the tires?
Either way, even it makes 300whp, I can only imagine what its like to drive.
it span the tire on the dyno in 3rd n 4 gear we had to tune 5 gear
does it spin drag radials ( I assume thats what you are running on the street, or r compunds) in 4th when driving as well? If so thats insane! What type of gearing do you have and what is your top speed in 4th. If youre running the tires you have in the pic then all I have to say is congratualtions on the dyno queen!
I'd like to see the dyno chart, I'm a bit skeptical
On a 74mm turbo, and an RB26, I was making 600rwhp and like 430tq on race gas....at 20psi
This isnt the prettiest dyno chart, but thats a significantly smaller turbo than a GT42.......
I agree those numbers don't sound right
  • 3 months later...
Damn...
Methinks that this is a perfect example of going 'a little too far'
i own the motor now it bent 4 valve's and broke the tip of a cam and cam gear and a new timing belt to get it runing! now i'm going to install it in my 260z but auto this time! i have it all the sds motor whole block
the pistons are cp there good thr eaglr rod are great
intake is great but head had 4 bent valves
